Startup Issue with V Rising - V Rising instance is stuck on starting
Application V Rising
Current State Starting
V Rising instance is stuck on starting. The server is operating and I am able to play on it but amp functionality is limited while server is stuck on starting
  • deployed instance
  • Set to PVE and then changed config to disable vac
  • updated and started instance. it is stuck on starting but the server is online and able to play on it
  • removed instance and started with the defaul setup. still stuck on starting
What’s the server IP address under Security and Privacy? Ideally make it 0.0.0.0 so that AMP’s RCON connects and it registers the server as started
