| Field |
Value |
| Operating System |
Linux - Ubuntu 22.04.3 on x86_64 |
| Product |
AMP ‘undefined’ v2.4.4.0 (Release) |
| Virtualization |
Xen |
| Application |
undefined |
| Module |
MinecraftModule |
| Running in Container |
No |
| Current State |
Ready |
upgraded to 2.4.4 and can no longer see console output in AMP on two minecraft servers both running different versions of the game - servers still run as normal.
- start instance
- start server
- no output to console
- stop server
- restart instance
- still no output to console
you need to update to 2.4.6.6 first
run this command as root with
sudo su -l
then you will run this to update the Cubecoders apt key
wget -O /usr/share/keyrings/repo.cubecoders.com.gpg https://repo.cubecoders.com/archive.key
then run the apt update and upgrade command
sudo apt update && sudo apt dist-upgrade -y
then when that is all done you will login as amp with this command
sudo su -l amp
and that will drop you into the amp user so you can run this command
ampinstmgr upgradeall
this will update everything. now try to access your console when that is done and see if it works. if it still not working let us know
this fixed my issue. I had 2.4.6.6 as my main instance, and tried to update my containers, but they stayed at 2.4.4 for some reason but following these steps they actually went to 2.4.6.6 and console works as expected now.
Thanks!
