Startup Issue with txAdmin - txAdmin, GTA RP Server
Operating System Windows - Windows Server 2025 on x86_64
Application txAdmin
Hello, I’m having a problem with txAdmin. When I start txAdmin via AMP, it runs normally, along with the scripts. The problem is that I keep getting an error in the txAdmin console. What do I need to do to make the error disappear so I can configure everything via txAdmin and AMP only starts, stops, or updates txAdmin?
This is the error message:
[script:monitor] [txAdmin] HeartBeat failed with code 0 and message: nil
  • Application Settings were searched for but not found.
  • ChatGPT was requested
  • I don’t know what to do anymore.
If you bind the instance to your local IP rather than 0.0.0.0, that error will go away
