Startup Issue with tModLoader - xception of type 'System.OutOfMemoryException'
Application tModLoader
(Its using only 0.41 from the 7.7gb that we have) and i cant find the settings to change that and its not bcs of the mods
  • loading mods into the mod file
  • Starting the server
  • Error xception of type ‘System.OutOfMemoryException’
    *[17:00:52.941] [Main Thread/WARN] [tML]: Total system memory usage exceeds installed physical memory, tModLoader will likely experience performance issues due to frequent page file access.
    [17:00:54.334] [.NET TP Worker/INFO] [Terraria]: Generating World: IdiotBox
    [17:00:54.342] [Main Thread/INFO] [StatusText]: 0.0% - - 0.
    [17:00:54.342] [Main Thread/INFO] [StatusText]: 0.0% - Generating world terrain - 0.
    [17:00:54.567] [.NET TP Worker/INFO] [tML]: tModLoader RAM usage during OutOfMemoryException: 389.1 MB
    [17:00:54.573] [.NET TP Worker/WARN] [tML]: Silently Caught Exception:
    System.OutOfMemoryException: Exception of type ‘System.OutOfMemoryException’ was thrown.
    at Terraria.TileData1.SetLength(UInt32 len) at Terraria.TileData1..cctor()
    at Terraria.TileData`1.get_ptr()
    at Terraria.Tile.set_HasTile(Boolean value)
    at Terraria.Tile.active(Boolean active)
    at Terraria.GameContent.Biomes.TerrainPass.FillColumn(Int32 x, Double worldSurface, Double rockLayer)
    at Terraria.GameContent.Biomes.TerrainPass.ApplyPass(GenerationProgress progress, GameConfiguration configuration)
    at Terraria.WorldBuilding.GenPass.Apply(GenerationProgress progress, GameConfiguration configuration)
    at Terraria.WorldBuilding.WorldGenerator.GenerateWorld(GenerationProgress progress)
    at Terraria.WorldGen.GenerateWorld_RunTasksAndFinish(Int32 seed, Stopwatch generationStopwatch, GenerationProgress customProgressObject)
    at Terraria.WorldGen.GenerateWorld(Int32 seed, GenerationProgress customProgressObject)
    at Terraria.IO.WorldFile.LoadWorld(Boolean loadFromCloud)
    at Terraria.WorldGen.serverLoadWorldCallBack()
    at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
    at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread)
    at System.Threading.ThreadPoolWorkQueue.Dispatch()
    at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
[17:00:54.574] [.NET TP Worker/FATAL] [tML]: Game ran out of memory. You’ll have to find which mod is consuming lots of memory, and contact the devs or remove it.
There’s a bug with the docker image currently, best bet might be to run it without docker till there’s a fix
Omfg Thx mate
You cant imagine how long i struggled to find something
its working without docker
The fix is known. Just needs Mike to spend 5 minutes to implement it.
In the meantime for tmodloader you can use greelan/amp:ubuntu as a custom image if you want to use docker
i have the same issue but im not using docker. using amp 2.6
