Startup Issue with tModLoader 1.4+ - World won't autocreate/autoload at launch
Product AMP ‘Callisto’ v2.5.1.4 - 20240801.2
Virtualization No
Application tModLoader 1.4+
I have created a tModLoader server and set it up inside AMP configuration page so that it autocreates a world named “world” at launch and autoloads it whenever the server restarts.
First, it doesn’t automatically creates this world. I have to do all the setup manually in the console (creating the world, choosing the name, its size, etc).
Second, it won’t autoload at launch. I always have to manually select the world in the console, set the number of players, the port, password, etc.
It seems like the server is ignoring certains parameters because changing other settings like “World Path” works fine.
  • Create a new tModLoader 1.4+ instance in AMP and update it
  • Set the required tModLoader settings in AMP (Created World Name, World File, etc)
  • Start the server
  • When starting, the server waits for the user to create and select a world instead of autocreating/autoloading it
