| Operating System | Linux - Debian GNU/Linux 12 on aarch64 |
| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | None |
| Application | Terraria |
| Module | GenericModule |
| Running in Container | No |
| Current State | Stopped |
I’ve tried recreating another instance and changing no settings, and it still doesn’t work. It seems to not be able to download the files necessary when i look at the logs.
It might have something to do with the steam credentials i gave. but i get no feedback as to if they were correct or incorrect or anything at all. This is my first time using AMP so I’m sorry if i misunderstood something.
LOGS:
[10:40:57] [Logger Info] : Specified executable '/home/amp/.ampdata/instances/Terraria01/Terraria/serverfiles/TerrariaServer does not exist. Updating application…
[10:40:57] [Core Info] : AMP is up to date.
[10:40:57] [Logger Info] : Skipping download - target already exists (./Terraria/serverfiles/terrariaserverconfig.txt)
[10:44:51] [Logger Activity] : Authentication attempt for user ssilz from 127.0.0.1
[10:44:51] [Core Activity] : Authentication success
[10:44:59] [API:ssilz Activity] : Updating the application.
[10:44:59] [Logger:ssilz Info] : Skipping download - target already exists (./Terraria/serverfiles/terrariaserverconfig.txt)
[10:45:22] [API:ssilz Activity] : Updating the application.
[10:45:22] [Logger:ssilz Info] : Skipping download - target already exists (./Terraria/serverfiles/terrariaserverconfig.txt)
[10:45:22] [steamcmdplugin:ssilz Warning] : /home/amp/.ampdata/instances/Terraria01/Terraria/steamcmd.sh: line 37: /home/amp/.ampdata/instances/Terraria01/Terraria/linux32/steamcmd: cannot execute binary file: Exec format error
[10:45:22] [steamcmdplugin:ssilz Warning] : 2023/11/21 11:45:22 socat[2014] E waitpid(): child 2015 exited with status 126
[10:45:22] [steamcmdplugin:ssilz Info] : SteamCMD Update successful
[10:45:22] [Logger:ssilz Info] : Skipping download - target already exists (/home/amp/.ampdata/instances/Terraria01/Terraria/serverfiles/.backupExclude)
[10:45:22] [Logger:ssilz Info] : Merging config file ./Terraria/serverfiles/terrariaserverconfig.txt (KVP format) using Unicode (UTF-8) encoding.
[10:45:22] [Logger:ssilz Info] : Specified executable '/home/amp/.ampdata/instances/Terraria01/Terraria/serverfiles/TerrariaServer does not exist. Updating application…
[10:45:22] [steamcmdplugin:ssilz Warning] : 2023/11/21 11:45:22 socat[2021] E waitpid(): child 2022 exited with status 126
[10:47:24] [Logger Activity] : Authentication attempt for user ssilz from 127.0.0.1
[10:47:24] [Core Activity] : Authentication success
[10:47:25] [API:ssilz Activity] : Starting the application.
[10:47:25] [Logger:ssilz Info] : Specified executable '/home/amp/.ampdata/instances/Terraria01/Terraria/serverfiles/TerrariaServer does not exist. Updating application…
[10:47:25] [Logger:ssilz Info] : Skipping download - target already exists (./Terraria/serverfiles/terrariaserverconfig.txt)
[10:47:25] [steamcmdplugin:ssilz Warning] : /home/amp/.ampdata/instances/Terraria01/Terraria/steamcmd.sh: line 37: /home/amp/.ampdata/instances/Terraria01/Terraria/linux32/steamcmd: cannot execute binary file: Exec format error
[10:47:25] [steamcmdplugin:ssilz Warning] : 2023/11/21 11:47:25 socat[2052] E waitpid(): child 2054 exited with status 126
[10:47:25] [steamcmdplugin:ssilz Info] : SteamCMD Update successful
[10:47:25] [Logger:ssilz Info] : Skipping download - target already exists (/home/amp/.ampdata/instances/Terraria01/Terraria/serverfiles/.backupExclude)
[10:47:25] [Logger:ssilz Info] : Merging config file ./Terraria/serverfiles/terrariaserverconfig.txt (KVP format) using Unicode (UTF-8) encoding.
[10:47:25] [steamcmdplugin:ssilz Warning] : 2023/11/21 11:47:25 socat[2060] E waitpid(): child 2061 exited with status 126
[10:48:21] [Logger Activity] : Authentication attempt for user ssilz from 127.0.0.1
[10:48:21] [Core Activity] : Authentication success
[10:59:17] [API:ssilz Activity] : Starting the application.
[10:59:17] [Logger:ssilz Info] : Specified executable '/home/amp/.ampdata/instances/Terraria01/Terraria/serverfiles/TerrariaServer does not exist. Updating application…
[10:59:17] [Logger:ssilz Info] : Skipping download - target already exists (./Terraria/serverfiles/terrariaserverconfig.txt)
[10:59:17] [steamcmdplugin:ssilz Warning] : /home/amp/.ampdata/instances/Terraria01/Terraria/steamcmd.sh: line 37: /home/amp/.ampdata/instances/Terraria01/Terraria/linux32/steamcmd: cannot execute binary file: Exec format error
[10:59:17] [steamcmdplugin:ssilz Warning] : 2023/11/21 11:59:17 socat[2210] E waitpid(): child 2211 exited with status 126
[10:59:17] [steamcmdplugin:ssilz Info] : SteamCMD Update successful
[10:59:17] [Logger:ssilz Info] : Skipping download - target already exists (/home/amp/.ampdata/instances/Terraria01/Terraria/serverfiles/.backupExclude)
[10:59:17] [Logger:ssilz Info] : Merging config file ./Terraria/serverfiles/terrariaserverconfig.txt (KVP format) using Unicode (UTF-8) encoding.
[10:59:17] [steamcmdplugin:ssilz Warning] : 2023/11/21 11:59:17 socat[2217] E waitpid(): child 2218 exited with status 126
- Create Terraria Instance
- Start Instance
- Try to start server
