Startup Issue with Team Fortress 2 - Cannot Start because of Binding issue
Application Team Fortress 2
I cannot start the server, I tried to bind the IP in many ways, even modifying the instance json manually, but it always fails with “You must select a specific IP address for this server to function correctly in AMP”
  • Create instance
  • Edit the instance and bind an IP in Ports settings
  • Try to start the server
  • The “You must select a specific IP address for this server to function correctly in AMP” error will appears
Just tested the fix, so it should be coming out shortly.
yea they dont care about older games, for example cs 1.6 wont even upgrade and start a working instance, you have to do everything manually
