Startup Issue with Sunkenland - Sunkenland server refuses to start
Operating System Windows - Windows 10 on x86_64
Virtualization VMware
Application Sunkenland
Current State Starting
Console Output:
Couldn’t create a Convex Mesh from source mesh “SM_pumpkin_07_p1” within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn’t create a Convex Mesh from source mesh “SM_pumpkin_09” within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn’t create a Convex Mesh from source mesh “SM_pumpkin_01_p1” within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn’t create a Convex Mesh from source mesh “SM_pumpkin_06_p1” within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn’t create a Convex Mesh from source mesh “SM_pumpkin_04_p1” within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn’t create a Convex Mesh from source mesh “SM_pumpkin_03_p1” within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
The referenced script on this Behaviour (Game Object ‘Jetstream Bowrider Engine’) is missing!
The referenced script on this Behaviour (Game Object ‘Motorboat Engine’) is missing!
The referenced script on this Behaviour (Game Object ‘Jetski Engine’) is missing!
The referenced script on this Behaviour (Game Object ‘Marine Fast Boat Console’) is missing!
The referenced script on this Behaviour (Game Object ‘Jetski Jet Pump’) is missing!
The referenced script on this Behaviour (Game Object ‘Helicopter Empennage’) is missing!
The referenced script on this Behaviour (Game Object ‘Helicopter Console’) is missing!
The referenced script on this Behaviour (Game Object ‘Jetski Controls’) is missing!
The referenced script on this Behaviour (Game Object ‘Marine Fast Boat Hull’) is missing!
The referenced script on this Behaviour (Game Object ‘Jetstream Bowrider Hull’) is missing!
The referenced script on this Behaviour (Game Object ‘Motorboat Gas Tank’) is missing!
The referenced script on this Behaviour (Game Object ‘Motorboat Hull’) is missing!
The referenced script on this Behaviour (Game Object ‘Helicopter Propeller’) is missing!
The referenced script on this Behaviour (Game Object ‘Z2_Scrap Raft Hull’) is missing!
The referenced script on this Behaviour (Game Object ‘Jetski Gas Tank’) is missing!
The referenced script on this Behaviour (Game Object ‘Jetstream Bowrider Console’) is missing!
The referenced script on this Behaviour (Game Object ‘Marine Fast Boat Engine’) is missing!
The referenced script on this Behaviour (Game Object ‘Helicopter Engine’) is missing!
The referenced script on this Behaviour (Game Object ‘Helicopter Gas Tank’) is missing!
The referenced script on this Behaviour (Game Object ‘Z1_Wooden Raft Hull’) is missing!
No mesh data available for mesh Plane001 on particle system Distortion. Make sure Read/Write Enabled is set in the importer to work on the particle system renderer
No mesh data available for mesh Plane001 on particle system Distortion_1. Make sure Read/Write Enabled is set in the importer to work on the particle system renderer
No mesh data available for mesh Plane001 on particle system Leafs. Make sure Read/Write Enabled is set in the importer to work on the particle system renderer
UnloadTime: 3.709500 ms
Sunkenland instance doesn’t seem to work anymore. Server hangs on “starting” forever
  • Create Sunkenland instance.
  • Install and attempt to start the new instance
  • Instance will be stuck on “Starting Sunkenland” with no clear error message.
