| Operating System | Windows - Windows 10 Pro on x86_64 |
| Product | AMP ‘Deimos’ v2.7.2.2 (Mainline) |
| Virtualization | None |
| Application | StarRupture |
| Module | GenericModule |
| Running in Container | No |
| Current State | Failed |
When hitting start the instance does not start up just says unable to run. I have also deleted and started again with a different config and still the same issue
- Created new instance, configured, and updated then pressed start and does not work
- Re installed and tried again
- implemented a different config still not working
