Startup Issue with Space Engineers (Torch) - Server starting on wrong port conflicting with project zomboid
Virtualization Podman
Application Space Engineers (Torch)
After attempting to change port still having “port already in use” error (System.Exception: Port is in use, check if another server is running on the same port) in starting space engineers server, changed port in both “SpaceEngineers-Dedicated.cfg” and in control panel for instance, maybe a clash with java ports between space engineers and project zomboid
  • Create project zombie instance
  • Then attempt to create space engineers instance
  • Start space engineers instance
