Startup Issue with Space Engineers - clean instance wont boot
Application Space Engineers
the game will no start and exits with code 1.
This is also with the docker instance.
Setup is on an Ubuntu 22.04
  • create clean instance for Space Engineers
  • Update instance and game.
  • start Instance no changes to config
  • also tried this bith the docker config
First make sure ampinstmgr is up to date - apt update && apt upgrade
Then make sure the docker image is up to date - docker pull cubecoders/ampbase:wine
Then create a new instance in docker
If you want to run it outside docker, you need wine 8, xvfb, cabextract and winbind installed first (as the popup when creating the instance tells you)
did all the upgrade’s and Updates, made a new instance direct with AMP.
i used Wine no luck also tried it with Wine8 but still the same error.
Are you setting it up with docker enabled on your amp install?
Yes also Enabled the Docker opting in AMP setting and then creating a new instance so its in a container no problems with other games
In the main amp web panel, select edit settings and in the container image, put cubecoders/ampbase:wine8 and select update under edit port and once that is done, go into the instance and update again and wait as it does need to update a few things
