| Operating System | Windows - Windows 10 Home on x86_64 |
| Product | AMP ‘Callisto’ v2.5.0.0 (Mainline) |
| Virtualization | HyperV |
| Application | Space Engineers |
| Module | GenericModule |
| Running in Container | No |
| Current State | Failed |
When I make this instance, for some reason, only via the AMP interface, I get the error “Error binding server endpoint: Only one usage of each socket address (protocol/network address/port) is normally permitted”. When I make a dedicated server via Steam, it works fine without any issues. I tried to restart AMP and the server, but nothing helped. I check if the port is used at some other place, but I cant find anything. I even tried to check with wirreshark.
- Make instance and keep the default ports
- download and start server
- Start server and watch it fail
Edit:
I found the problem. The port which caused the issue was 25565. I also run multiple Minecraft servers and one of them had the default Minecraft server port 25565.
