Startup Issue with Source Dedicated Server - Stuck on "Application State: Starting"
Application Source Dedicated Server
Module srcdsModule
Current State Starting
Hello for some reason the State of the application is stuck on “starting” for some quite time (20mins). I also looked at the log and the last entry is [00:22:08] [API:EnderB0YHD Activity] : Starting the application. Any help would be really appreciated. Thank you :slight_smile:
Here is the log
[00:11:43] [Core Info]            : Starting AMP version 2.5.0.0 (Callisto), built 22/03/2024 17:32
[00:11:43] [Core Info]            : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[00:11:43] [Logger Info]          : Purging old audit logs (this may take a moment)...
[00:11:43] [Core Info]            : Running in a Docker environment.
[00:11:43] [Core Info]            : OS: Linux / x86_64
[00:11:43] [Core Info]            : CPU: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz (2C/4T)
[00:11:43] [Core Info]            : RAM: 15748MB
[00:11:43] [Core Info]            : AMP Instance ID: da36dc5e-5ab7-41a2-bb04-c286c9c0c3ef
[00:11:44] [Loader Info]          : Loaded srcdsModule version 1.0.0.1 by CubeCoders Limited
[00:11:44] [Core Info]            : Metrics publishing is enabled at udp://localhost:12820.
[00:11:44] [Loader Info]          : Loaded FileManagerPlugin by CubeCoders Limited
[00:11:44] [Loader Info]          : Loaded EmailSenderPlugin by CubeCoders Limited
[00:11:44] [Loader Info]          : Loaded WebRequestPlugin by CubeCoders Limited
[00:11:44] [Loader Info]          : Loaded LocalFileBackupPlugin by CubeCoders Limited
[00:11:44] [Loader Info]          : Loaded CommonCorePlugin by CubeCoders Limited
[00:11:44] [Loader Info]          : srcdsModule requests dependency steamcmdplugin...
[00:11:44] [Loader Info]          : Loaded steamcmdplugin by CubeCoders Limited
[00:11:44] [Loader Info]          : srcdsModule requests dependency RCONPlugin...
[00:11:44] [Loader Info]          : Loaded RCONPlugin by CubeCoders Limited
[00:11:44] [Core Info]            : Licence Present: AMP Standard Edition
[00:11:44] [FileManager Notice]   : No SSH keypair available for embedded server, generating new keypair...
[00:11:44] [FileManager Notice]   : Generated new keypair with fingerprint cvoRqbvylu6GE2bV9rL6T9mxbBZ6B3LDu9bwSfGx+V8=
[00:11:44] [FileManager Notice]   : Using keypair with fingerprint cvoRqbvylu6GE2bV9rL6T9mxbBZ6B3LDu9bwSfGx+V8=
[00:11:45] [FileManager Info]     : SFTP Server started on 0.0.0.0:2224
[00:11:45] [Webserver Info]       : Websockets are enabled.
[00:11:45] [Webserver Info]       : Webserver started on http://127.0.0.1:8081
[00:11:45] [Logger Info]          : RouterTimer@10Hz with 2 jobs started
[00:11:45] [Core Info]            : Checking for AMP updates...
[00:11:45] [Core Info]            : Startup mode is UpdateApplication.
[00:11:45] [Core Info]            : AMP is up to date.
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
[  0%] Checking for available update...
[----] Downloading update (0 of 59594 KB)...
[  0%] Downloading update (0 of 59594 KB)...
[  0%] Downloading update (654 of 59594 KB)...
[  1%] Downloading update (1475 of 59594 KB)...
[  2%] Downloading update (2528 of 59594 KB)...
[  4%] Downloading update (3759 of 59594 KB)...
[  6%] Downloading update (4991 of 59594 KB)...
[  8%] Downloading update (5968 of 59594 KB)...
[ 10%] Downloading update (6715 of 59594 KB)...
[ 11%] Downloading update (7649 of 59594 KB)...
[ 12%] Downloading update (8646 of 59594 KB)...
[ 14%] Downloading update (9640 of 59594 KB)...
[ 16%] Downloading update (10628 of 59594 KB)...
[ 17%] Downloading update (11689 of 59594 KB)...
[ 19%] Downloading update (12741 of 59594 KB)...
[ 21%] Downloading update (13877 of 59594 KB)...
[ 23%] Downloading update (14832 of 59594 KB)...
[ 24%] Downloading update (14849 of 59594 KB)...
[ 24%] Downloading update (14863 of 59594 KB)...
[ 24%] Downloading update (15848 of 59594 KB)...
[ 26%] Downloading update (16731 of 59594 KB)...
[ 28%] Downloading update (17519 of 59594 KB)...
[ 29%] Downloading update (18447 of 59594 KB)...
[ 30%] Downloading update (19506 of 59594 KB)...
[ 32%] Downloading update (20590 of 59594 KB)...
[ 34%] Downloading update (21594 of 59594 KB)...
[ 36%] Downloading update (22687 of 59594 KB)...
[ 38%] Downloading update (23538 of 59594 KB)...
[ 39%] Downloading update (24599 of 59594 KB)...
[ 41%] Downloading update (25664 of 59594 KB)...
[ 43%] Downloading update (26666 of 59594 KB)...
[ 44%] Downloading update (27846 of 59594 KB)...
[ 46%] Downloading update (29005 of 59594 KB)...
[ 48%] Downloading update (30160 of 59594 KB)...
[ 50%] Downloading update (31206 of 59594 KB)...
[ 52%] Downloading update (32175 of 59594 KB)...
[ 53%] Downloading update (33295 of 59594 KB)...
[ 55%] Downloading update (34301 of 59594 KB)...
[ 57%] Downloading update (35455 of 59594 KB)...
[ 59%] Downloading update (36577 of 59594 KB)...
[ 61%] Downloading update (37736 of 59594 KB)...
[ 63%] Downloading update (39119 of 59594 KB)...
[ 65%] Downloading update (39674 of 59594 KB)...
[ 66%] Downloading update (40405 of 59594 KB)...
[ 67%] Downloading update (41017 of 59594 KB)...
[ 68%] Downloading update (41740 of 59594 KB)...
[ 70%] Downloading update (42507 of 59594 KB)...
[ 71%] Downloading update (43259 of 59594 KB)...
[ 72%] Downloading update (44027 of 59594 KB)...
[ 73%] Downloading update (44467 of 59594 KB)...
[ 74%] Downloading update (45208 of 59594 KB)...
[ 75%] Downloading update (45974 of 59594 KB)...
[ 77%] Downloading update (46721 of 59594 KB)...
[ 78%] Downloading update (47467 of 59594 KB)...
[ 79%] Downloading update (47971 of 59594 KB)...
[ 80%] Downloading update (48744 of 59594 KB)...
[ 81%] Downloading update (49444 of 59594 KB)...
[ 82%] Downloading update (50250 of 59594 KB)...
[ 84%] Downloading update (50954 of 59594 KB)...
[ 85%] Downloading update (51680 of 59594 KB)...
[ 86%] Downloading update (52213 of 59594 KB)...
[ 87%] Downloading update (52985 of 59594 KB)...
[ 88%] Downloading update (53805 of 59594 KB)...
[ 90%] Downloading update (54557 of 59594 KB)...
[ 91%] Downloading update (55208 of 59594 KB)...
[ 92%] Downloading update (55975 of 59594 KB)...
[ 93%] Downloading update (56702 of 59594 KB)...
[ 95%] Downloading update (57464 of 59594 KB)...
[ 96%] Downloading update (58227 of 59594 KB)...
[ 97%] Downloading update (59006 of 59594 KB)...
[ 99%] Downloading update (59594 of 59594 KB)...
[100%] Download Complete.
[----] Applying update...
[----] Extracting package...
[----] Installing update...
[----] Cleaning up...
[----] Update complete, launching...
tid(94) burning pthread_key_t == 0 so we never use it
/tmp/dumps: insufficient permissions - delete and recreate
minidumps folder is set to /tmp/dumps
[  0%] Checking for available updates...
[  0%] Downloading update...
[----] Download complete.
[----] Update complete, launching Steamcmd...
[00:12:12] [steamcmdplugin Warning] : steamcmd.sh[77]: Restarting steamcmd by request...
UpdateUI: skip show logotid(107) burning pthread_key_t == 0 so we never use it
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1709846822
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "4020"
Waiting for user info...OK
app_update 4020 validate
 Update state (0x61) downloading, progress: 0.08 (3145728 / 3932881010)
 Update state (0x61) downloading, progress: 0.90 (35567868 / 3932881010)
 Update state (0x61) downloading, progress: 1.69 (66441260 / 3932881010)
 Update state (0x61) downloading, progress: 1.95 (76574239 / 3932881010)
 Update state (0x61) downloading, progress: 2.05 (80520867 / 3932881010)
 Update state (0x61) downloading, progress: 2.37 (93112784 / 3932881010)
 Update state (0x61) downloading, progress: 2.60 (102220823 / 3932881010)
 Update state (0x61) downloading, progress: 3.10 (121899174 / 3932881010)
 Update state (0x61) downloading, progress: 3.33 (131113982 / 3932881010)
 Update state (0x61) downloading, progress: 3.64 (143069869 / 3932881010)
 Update state (0x61) downloading, progress: 3.98 (156715369 / 3932881010)
 Update state (0x61) downloading, progress: 4.25 (167228772 / 3932881010)
 Update state (0x61) downloading, progress: 4.62 (181887255 / 3932881010)
 Update state (0x61) downloading, progress: 5.01 (196950622 / 3932881010)
 Update state (0x61) downloading, progress: 5.39 (211911511 / 3932881010)
 Update state (0x61) downloading, progress: 5.78 (227193853 / 3932881010)
 Update state (0x61) downloading, progress: 6.31 (248165288 / 3932881010)
 Update state (0x61) downloading, progress: 6.77 (266108822 / 3932881010)
 Update state (0x61) downloading, progress: 7.34 (288744407 / 3932881010)
 Update state (0x61) downloading, progress: 7.94 (312313429 / 3932881010)
 Update state (0x61) downloading, progress: 8.41 (330607557 / 3932881010)
 Update state (0x61) downloading, progress: 9.07 (356839369 / 3932881010)
 Update state (0x61) downloading, progress: 9.56 (376171595 / 3932881010)
 Update state (0x61) downloading, progress: 9.91 (389803083 / 3932881010)
 Update state (0x61) downloading, progress: 10.12 (398191523 / 3932881010)
 Update state (0x61) downloading, progress: 10.43 (410025832 / 3932881010)
 Update state (0x61) downloading, progress: 10.83 (425778228 / 3932881010)
 Update state (0x61) downloading, progress: 11.18 (439563661 / 3932881010)
 Update state (0x61) downloading, progress: 11.79 (463713397 / 3932881010)
 Update state (0x61) downloading, progress: 12.67 (498438180 / 3932881010)
[00:13:22] [Core Activity]        : Authentication attempt for user EnderB0YHD from 127.0.0.1
[00:13:22] [Core Activity]        : Authentication success
 Update state (0x61) downloading, progress: 13.20 (519263534 / 3932881010)
 Update state (0x61) downloading, progress: 13.71 (539186846 / 3932881010)
 Update state (0x61) downloading, progress: 14.22 (559231853 / 3932881010)
 Update state (0x61) downloading, progress: 14.92 (586687855 / 3932881010)
 Update state (0x61) downloading, progress: 15.40 (605562027 / 3932881010)
 Update state (0x61) downloading, progress: 15.99 (628721538 / 3932881010)
 Update state (0x61) downloading, progress: 16.41 (645498754 / 3932881010)
 Update state (0x61) downloading, progress: 16.68 (655985783 / 3932881010)
 Update state (0x61) downloading, progress: 17.39 (683875289 / 3932881010)
 Update state (0x61) downloading, progress: 18.16 (714284091 / 3932881010)
 Update state (0x61) downloading, progress: 18.53 (728686155 / 3932881010)
 Update state (0x61) downloading, progress: 18.73 (736733154 / 3932881010)
 Update state (0x61) downloading, progress: 19.40 (762911703 / 3932881010)
 Update state (0x61) downloading, progress: 19.64 (772348887 / 3932881010)
 Update state (0x61) downloading, progress: 19.90 (782834174 / 3932881010)
 Update state (0x61) downloading, progress: 20.12 (791222782 / 3932881010)
 Update state (0x61) downloading, progress: 20.54 (807999998 / 3932881010)
 Update state (0x61) downloading, progress: 20.94 (823678880 / 3932881010)
 Update state (0x61) downloading, progress: 21.16 (832067488 / 3932881010)
 Update state (0x61) downloading, progress: 21.50 (845759100 / 3932881010)
 Update state (0x61) downloading, progress: 21.82 (858207307 / 3932881010)
 Update state (0x61) downloading, progress: 22.20 (873170987 / 3932881010)
 Update state (0x61) downloading, progress: 22.58 (888069528 / 3932881010)
 Update state (0x61) downloading, progress: 22.91 (901202953 / 3932881010)
 Update state (0x61) downloading, progress: 23.18 (911688557 / 3932881010)
 Update state (0x61) downloading, progress: 23.47 (923222893 / 3932881010)
 Update state (0x61) downloading, progress: 23.82 (936854381 / 3932881010)
 Update state (0x61) downloading, progress: 24.14 (949570289 / 3932881010)
 Update state (0x61) downloading, progress: 24.44 (961104625 / 3932881010)
 Update state (0x61) downloading, progress: 24.86 (977880580 / 3932881010)
 Update state (0x61) downloading, progress: 25.24 (992560644 / 3932881010)
 Update state (0x61) downloading, progress: 25.61 (1007240708 / 3932881010)
 Update state (0x61) downloading, progress: 25.90 (1018774090 / 3932881010)
 Update state (0x61) downloading, progress: 26.33 (1035551306 / 3932881010)
 Update state (0x61) downloading, progress: 26.86 (1056522712 / 3932881010)
 Update state (0x61) downloading, progress: 27.13 (1067008137 / 3932881010)
 Update state (0x61) downloading, progress: 27.37 (1076247772 / 3932881010)
 Update state (0x61) downloading, progress: 27.63 (1086733532 / 3932881010)
 Update state (0x61) downloading, progress: 28.01 (1101413596 / 3932881010)
 Update state (0x61) downloading, progress: 28.27 (1111899336 / 3932881010)
 Update state (0x61) downloading, progress: 28.57 (1123433672 / 3932881010)
 Update state (0x61) downloading, progress: 28.86 (1134967945 / 3932881010)
 Update state (0x61) downloading, progress: 29.15 (1146502281 / 3932881010)
 Update state (0x61) downloading, progress: 29.34 (1153842282 / 3932881010)
 Update state (0x61) downloading, progress: 29.60 (1164328042 / 3932881010)
 Update state (0x61) downloading, progress: 29.81 (1172229215 / 3932881010)
 Update state (0x61) downloading, progress: 30.21 (1187957855 / 3932881010)
 Update state (0x61) downloading, progress: 30.45 (1197526117 / 3932881010)
 Update state (0x61) downloading, progress: 30.77 (1210108968 / 3932881010)
 Update state (0x61) downloading, progress: 31.36 (1233512637 / 3932881010)
 Update state (0x61) downloading, progress: 31.64 (1244196835 / 3932881010)
 Update state (0x61) downloading, progress: 31.91 (1254975678 / 3932881010)
 Update state (0x61) downloading, progress: 32.39 (1273850046 / 3932881010)
 Update state (0x61) downloading, progress: 32.68 (1285384222 / 3932881010)
 Update state (0x61) downloading, progress: 33.06 (1300199243 / 3932881010)
 Update state (0x61) downloading, progress: 33.38 (1312960059 / 3932881010)
 Update state (0x61) downloading, progress: 33.70 (1325542971 / 3932881010)
 Update state (0x61) downloading, progress: 34.08 (1340223035 / 3932881010)
 Update state (0x61) downloading, progress: 34.62 (1361427992 / 3932881010)
 Update state (0x61) downloading, progress: 34.96 (1375059480 / 3932881010)
 Update state (0x61) downloading, progress: 35.68 (1403432990 / 3932881010)
 Update state (0x61) downloading, progress: 36.08 (1418972873 / 3932881010)
 Update state (0x61) downloading, progress: 36.49 (1435256616 / 3932881010)
 Update state (0x61) downloading, progress: 37.04 (1456735337 / 3932881010)
 Update state (0x61) downloading, progress: 37.55 (1476603780 / 3932881010)
 Update state (0x61) downloading, progress: 38.24 (1504038654 / 3932881010)
 Update state (0x61) downloading, progress: 38.64 (1519475223 / 3932881010)
 Update state (0x61) downloading, progress: 39.12 (1538414394 / 3932881010)
 Update state (0x61) downloading, progress: 39.64 (1558886612 / 3932881010)
 Update state (0x61) downloading, progress: 40.12 (1578061854 / 3932881010)
 Update state (0x61) downloading, progress: 40.61 (1597199983 / 3932881010)
 Update state (0x61) downloading, progress: 41.01 (1612928623 / 3932881010)
 Update state (0x61) downloading, progress: 41.93 (1648930507 / 3932881010)
 Update state (0x61) downloading, progress: 43.17 (1697932582 / 3932881010)
 Update state (0x61) downloading, progress: 43.74 (1720303818 / 3932881010)
 Update state (0x61) downloading, progress: 44.11 (1734847211 / 3932881010)
 Update state (0x61) downloading, progress: 44.63 (1755392759 / 3932881010)
 Update state (0x61) downloading, progress: 45.06 (1772169975 / 3932881010)
 Update state (0x61) downloading, progress: 45.49 (1788950167 / 3932881010)
 Update state (0x61) downloading, progress: 45.94 (1806910196 / 3932881010)
 Update state (0x61) downloading, progress: 46.58 (1832114030 / 3932881010)
 Update state (0x61) downloading, progress: 46.96 (1846794094 / 3932881010)
 Update state (0x61) downloading, progress: 47.59 (1871563316 / 3932881010)
 Update state (0x61) downloading, progress: 48.07 (1890437684 / 3932881010)
 Update state (0x61) downloading, progress: 48.40 (1903464007 / 3932881010)
 Update state (0x61) downloading, progress: 48.85 (1921025866 / 3932881010)
 Update state (0x61) downloading, progress: 49.76 (1956898314 / 3932881010)
 Update state (0x61) downloading, progress: 50.21 (1974710218 / 3932881010)
 Update state (0x61) downloading, progress: 50.72 (1994633689 / 3932881010)
 Update state (0x61) downloading, progress: 51.25 (2015668583 / 3932881010)
 Update state (0x61) downloading, progress: 52.04 (2046574679 / 3932881010)
 Update state (0x61) downloading, progress: 52.46 (2063351895 / 3932881010)
 Update state (0x61) downloading, progress: 53.01 (2084656381 / 3932881010)
 Update state (0x61) downloading, progress: 53.73 (2113150906 / 3932881010)
 Update state (0x61) downloading, progress: 53.98 (2122877392 / 3932881010)
 Update state (0x61) downloading, progress: 54.31 (2136104870 / 3932881010)
 Update state (0x61) downloading, progress: 54.90 (2159173542 / 3932881010)
 Update state (0x61) downloading, progress: 55.28 (2173918943 / 3932881010)
 Update state (0x61) downloading, progress: 55.49 (2182307551 / 3932881010)
 Update state (0x61) downloading, progress: 55.76 (2192793311 / 3932881010)
 Update state (0x61) downloading, progress: 55.94 (2200133343 / 3932881010)
 Update state (0x61) downloading, progress: 56.29 (2213764831 / 3932881010)
 Update state (0x61) downloading, progress: 56.56 (2224250591 / 3932881010)
 Update state (0x61) downloading, progress: 57.02 (2242556696 / 3932881010)
 Update state (0x61) downloading, progress: 57.29 (2253042456 / 3932881010)
 Update state (0x61) downloading, progress: 57.55 (2263480552 / 3932881010)
 Update state (0x61) downloading, progress: 57.82 (2273966312 / 3932881010)
 Update state (0x61) downloading, progress: 58.25 (2290743528 / 3932881010)
 Update state (0x61) downloading, progress: 58.56 (2303003225 / 3932881010)
 Update state (0x61) downloading, progress: 58.80 (2312440409 / 3932881010)
 Update state (0x61) downloading, progress: 59.23 (2329494470 / 3932881010)
 Update state (0x61) downloading, progress: 59.72 (2348718144 / 3932881010)
 Update state (0x61) downloading, progress: 60.03 (2360969759 / 3932881010)
 Update state (0x61) downloading, progress: 60.31 (2372088872 / 3932881010)
 Update state (0x61) downloading, progress: 60.77 (2389917488 / 3932881010)
 Update state (0x61) downloading, progress: 60.96 (2397370809 / 3932881010)
 Update state (0x61) downloading, progress: 61.40 (2414781912 / 3932881010)
 Update state (0x61) downloading, progress: 61.77 (2429461976 / 3932881010)
 Update state (0x61) downloading, progress: 62.20 (2446239186 / 3932881010)
 Update state (0x61) downloading, progress: 62.39 (2453579218 / 3932881010)
 Update state (0x61) downloading, progress: 62.71 (2466162130 / 3932881010)
 Update state (0x61) downloading, progress: 63.05 (2479757430 / 3932881010)
 Update state (0x61) downloading, progress: 63.45 (2495486070 / 3932881010)
 Update state (0x61) downloading, progress: 63.85 (2511248408 / 3932881010)
 Update state (0x61) downloading, progress: 64.12 (2521734168 / 3932881010)
 Update state (0x61) downloading, progress: 64.47 (2535403238 / 3932881010)
 Update state (0x61) downloading, progress: 64.68 (2543791846 / 3932881010)
 Update state (0x61) downloading, progress: 65.00 (2556374758 / 3932881010)
 Update state (0x61) downloading, progress: 65.35 (2570006246 / 3932881010)
 Update state (0x61) downloading, progress: 65.69 (2583637734 / 3932881010)
 Update state (0x61) downloading, progress: 66.09 (2599366374 / 3932881010)
 Update state (0x61) downloading, progress: 66.47 (2614046438 / 3932881010)
 Update state (0x61) downloading, progress: 66.79 (2626629350 / 3932881010)
 Update state (0x61) downloading, progress: 67.13 (2640305726 / 3932881010)
 Update state (0x61) downloading, progress: 67.35 (2648695918 / 3932881010)
 Update state (0x61) downloading, progress: 67.75 (2664446740 / 3932881010)
 Update state (0x61) downloading, progress: 68.03 (2675381618 / 3932881010)
 Update state (0x61) downloading, progress: 68.58 (2697099933 / 3932881010)
 Update state (0x61) downloading, progress: 69.00 (2713877149 / 3932881010)
 Update state (0x61) downloading, progress: 69.38 (2728557213 / 3932881010)
 Update state (0x61) downloading, progress: 69.75 (2743237277 / 3932881010)
 Update state (0x61) downloading, progress: 70.18 (2760014493 / 3932881010)
 Update state (0x61) downloading, progress: 70.55 (2774694557 / 3932881010)
 Update state (0x61) downloading, progress: 70.88 (2787701277 / 3932881010)
 Update state (0x61) downloading, progress: 71.29 (2803654960 / 3932881010)
 Update state (0x61) downloading, progress: 71.53 (2813092144 / 3932881010)
 Update state (0x61) downloading, progress: 71.93 (2828802933 / 3932881010)
 Update state (0x61) downloading, progress: 72.30 (2843482997 / 3932881010)
 Update state (0x61) downloading, progress: 72.78 (2862401273 / 3932881010)
 Update state (0x61) downloading, progress: 73.10 (2874984265 / 3932881010)
 Update state (0x61) downloading, progress: 73.48 (2889927201 / 3932881010)
 Update state (0x61) downloading, progress: 73.83 (2903558729 / 3932881010)
 Update state (0x61) downloading, progress: 74.24 (2919623473 / 3932881010)
 Update state (0x61) downloading, progress: 74.61 (2934303537 / 3932881010)
 Update state (0x61) downloading, progress: 74.98 (2948983601 / 3932881010)
 Update state (0x61) downloading, progress: 75.24 (2959168502 / 3932881010)
 Update state (0x61) downloading, progress: 75.77 (2979986861 / 3932881010)
 Update state (0x61) downloading, progress: 76.47 (3007600317 / 3932881010)
 Update state (0x61) downloading, progress: 77.58 (3051006924 / 3932881010)
 Update state (0x61) downloading, progress: 78.43 (3084579548 / 3932881010)
 Update state (0x61) downloading, progress: 78.78 (3098211036 / 3932881010)
 Update state (0x61) downloading, progress: 79.10 (3110793948 / 3932881010)
 Update state (0x61) downloading, progress: 79.44 (3124425444 / 3932881010)
 Update state (0x61) downloading, progress: 79.90 (3142251612 / 3932881010)
 Update state (0x61) downloading, progress: 80.39 (3161597438 / 3932881010)
 Update state (0x61) downloading, progress: 80.90 (3181572367 / 3932881010)
 Update state (0x61) downloading, progress: 81.21 (3194056270 / 3932881010)
 Update state (0x61) downloading, progress: 81.46 (3203901908 / 3932881010)
 Update state (0x61) downloading, progress: 81.78 (3216484820 / 3932881010)
 Update state (0x61) downloading, progress: 82.10 (3229067732 / 3932881010)
 Update state (0x61) downloading, progress: 82.32 (3237456340 / 3932881010)
 Update state (0x61) downloading, progress: 82.64 (3250039252 / 3932881010)
 Update state (0x61) downloading, progress: 82.90 (3260525012 / 3932881010)
 Update state (0x61) downloading, progress: 83.22 (3273107924 / 3932881010)
 Update state (0x61) downloading, progress: 83.65 (3289885140 / 3932881010)
 Update state (0x61) downloading, progress: 84.00 (3303516628 / 3932881010)
 Update state (0x61) downloading, progress: 84.29 (3315050964 / 3932881010)
 Update state (0x61) downloading, progress: 84.64 (3328682452 / 3932881010)
 Update state (0x61) downloading, progress: 84.88 (3338119636 / 3932881010)
 Update state (0x61) downloading, progress: 85.23 (3352046588 / 3932881010)
 Update state (0x61) downloading, progress: 85.52 (3363580924 / 3932881010)
 Update state (0x61) downloading, progress: 85.90 (3378260988 / 3932881010)
 Update state (0x61) downloading, progress: 86.22 (3390843900 / 3932881010)
 Update state (0x61) downloading, progress: 86.56 (3404404724 / 3932881010)
 Update state (0x61) downloading, progress: 87.07 (3424327668 / 3932881010)
 Update state (0x61) downloading, progress: 87.64 (3446698392 / 3932881010)
 Update state (0x61) downloading, progress: 88.03 (3462245784 / 3932881010)
 Update state (0x61) downloading, progress: 88.38 (3475877272 / 3932881010)
 Update state (0x61) downloading, progress: 88.84 (3494115300 / 3932881010)
 Update state (0x61) downloading, progress: 89.35 (3513980948 / 3932881010)
 Update state (0x61) downloading, progress: 89.70 (3527612436 / 3932881010)
 Update state (0x61) downloading, progress: 90.07 (3542216274 / 3932881010)
 Update state (0x61) downloading, progress: 90.47 (3558032514 / 3932881010)
 Update state (0x61) downloading, progress: 90.84 (3572712578 / 3932881010)
 Update state (0x61) downloading, progress: 91.51 (3599064347 / 3932881010)
 Update state (0x61) downloading, progress: 91.94 (3615841563 / 3932881010)
 Update state (0x61) downloading, progress: 92.38 (3633144915 / 3932881010)
 Update state (0x61) downloading, progress: 92.94 (3655228611 / 3932881010)
 Update state (0x61) downloading, progress: 93.38 (3672711832 / 3932881010)
 Update state (0x61) downloading, progress: 94.05 (3698926232 / 3932881010)
 Update state (0x61) downloading, progress: 94.82 (3728984636 / 3932881010)
 Update state (0x61) downloading, progress: 95.60 (3759725084 / 3932881010)
 Update state (0x61) downloading, progress: 96.14 (3781064360 / 3932881010)
 Update state (0x61) downloading, progress: 96.90 (3811007114 / 3932881010)
 Update state (0x61) downloading, progress: 97.27 (3825334308 / 3932881010)
 Update state (0x61) downloading, progress: 98.25 (3863948345 / 3932881010)
 Update state (0x61) downloading, progress: 99.23 (3902530776 / 3932881010)
 Update state (0x61) downloading, progress: 100.00 (3932881010 / 3932881010)
 Update state (0x81) verifying update, progress: 5.72 (225148148 / 3932881010)
 Update state (0x81) verifying update, progress: 17.84 (701433164 / 3932881010)
 Update state (0x81) verifying update, progress: 29.85 (1173857216 / 3932881010)
 Update state (0x81) verifying update, progress: 41.79 (1643718321 / 3932881010)
 Update state (0x81) verifying update, progress: 53.95 (2121607528 / 3932881010)
 Update state (0x81) verifying update, progress: 65.87 (2590445780 / 3932881010)
 Update state (0x81) verifying update, progress: 77.95 (3065816641 / 3932881010)
 Update state (0x81) verifying update, progress: 89.88 (3535045730 / 3932881010)
 Update state (0x101) committing, progress: 100.00 (3932881010 / 3932881010)
Success! App '4020' fully installed.
quit
[00:20:36] [steamcmdplugin Info]  : SteamCMD Update successful
[00:20:58] [API:EnderB0YHD Activity] : Changing setting srcdsModule.SRCDS.ServerName to EnderB0YHD - Powered by AMP
[00:21:03] [API:EnderB0YHD Activity] : Changing setting srcdsModule.SRCDS.ServerPassword to EnderB0YHD1234
[00:21:11] [API:EnderB0YHD Activity] : Changing setting srcdsModule.SRCDS.workshop_collection to 367905958
[00:21:27] [API:EnderB0YHD Activity] : Protected setting srcdsModule.SRCDS.workshop_auth_key changed.
[00:21:30] [API:EnderB0YHD Activity] : Changing setting srcdsModule.SRCDS.gmod_gamemode to ttt
[00:21:34] [API:EnderB0YHD Activity] : Changing setting srcdsModule.SRCDS.ServerIPBinding to 192.168.178.32
[00:21:59] [API:EnderB0YHD Activity] : Protected setting srcdsModule.SRCDS.GSLT changed.
[00:22:06] [Core Activity]        : Authentication attempt for user EnderB0YHD from 127.0.0.1
[00:22:06] [Core Activity]        : Authentication success
  • Start server from the web app
  • Restart the server from the web app
  • Reinstalling the instance
Just going to point out that you shared your server password in the logs there.
This could be caused by a few things:
  1. Selecting an invalid map, which just causes the server to sit and do nothing.
  2. A bad GSLT token
  3. A configuration file that is overriding the RCON password set by AMP.
