Startup Issue with Sons Of The Forest - Sons of the Forest server not starting
Operating System Linux - CentOS Stream 9 on x86_64
Product AMP ‘Decadeus’ v2.4.5.4 (Mainline)
Application Sons Of The Forest
Hi, I am trying to use the Sons of the Forest image to create a server, however, it doesn’t seem to start.
Also, the configuration file get replaced with the default values everytime I try to start the server.
This is all the Console output I get:
1:55:32
[UnityMemory] Configuration Parameters - Can be set up in boot.config
“memorysetup-bucket-allocator-granularity=16”
“memorysetup-bucket-allocator-bucket-count=8”
“memorysetup-bucket-allocator-block-size=4194304”
“memorysetup-bucket-allocator-block-count=1”
“memorysetup-main-allocator-block-size=16777216”
“memorysetup-thread-allocator-block-size=16777216”
“memorysetup-gfx-main-allocator-block-size=16777216”
“memorysetup-gfx-thread-allocator-block-size=16777216”
“memorysetup-cache-allocator-block-size=4194304”
“memorysetup-typetree-allocator-block-size=2097152”
“memorysetup-profiler-bucket-allocator-granularity=16”
“memorysetup-profiler-bucket-allocator-bucket-count=8”
“memorysetup-profiler-bucket-allocator-block-size=4194304”
“memorysetup-profiler-bucket-allocator-block-count=1”
“memorysetup-profiler-allocator-block-size=16777216”
“memorysetup-profiler-editor-allocator-block-size=1048576”
“memorysetup-temp-allocator-size-main=4194304”
“memorysetup-job-temp-allocator-block-size=2097152”
“memorysetup-job-temp-allocator-block-size-background=1048576”
“memorysetup-job-temp-allocator-reduction-small-platforms=262144”
“memorysetup-temp-allocator-size-background-worker=32768”
“memorysetup-temp-allocator-size-job-worker=262144”
“memorysetup-temp-allocator-size-preload-manager=262144”
“memorysetup-temp-allocator-size-nav-mesh-worker=65536”
“memorysetup-temp-allocator-size-audio-worker=65536”
“memorysetup-temp-allocator-size-cloud-worker=32768”
“memorysetup-temp-allocator-size-gfx=262144”
Thanks!
  • Centos 9 Stream. Installed Xvfb and Wine
  • Created instance
  • Updated instance
  • Tried to start server
