Field | Value |
Product | AMP ‘Phobos’ v2.6.2.6 (Mainline) |
Virtualization | Docker |
Application | Sons Of The Forest |
Module | GenericModule |
Running in Container | Yes |
Current State | Starting |
UPDATED AMP INSTANCE. RESTARTED VPS AND AMPED ONCE UPDATE WAS FINISHED. RAN MANAUL START FROM CONSOLE WHEN INTIAL START WOULD NOT WORK. CONSOLE IS SHOWING AN API ISSUE WITH STEAM VIA THE BELOW ERROR. src\common\interfacemap.cpp (874) : Assertion Failed: IPC call to IClientHTTP::ReleaseHTTPRequest returned failure code 12
- UPDATE AMP INSTANCE
- RESTART VPS ONCE UPDATE WAS FINISHED
- RESTARTED AMPED INSTANCE ONCE VPS WAS FINSHED BOOTING
- ATTEMPED AMP SERVER START FOR SONS OF THE FOREST
- ONCE START PROCCESS FAILED ATTEMPTED MANUAL START VIA CONSOLE COMMAND
- PULLED CONSOLE ERRORS TO SEND TO SUPPORT
