Startup Issue with Satisfactory - TCP and UDP port for Satisfactory change to UDP only
Application Satisfactory
1.0 of Satisfactory was released today and with it an update to the ports used for dedicated servers. It is no using TCP and UDP port 7777 only. When changing this in the manage section when theinstance is stopped it reverts back to UDP on both when trying to launch it.
  • Updated the game
  • Updated UDP and TCP ports
  • Unable to start the instance
RESOLVED
This seems to have been solved by AMP. What i did was to Delete the Satisfactory instance. Ensure AMP is up to date by going to Support and Updates - Upgrade this instance. After the system has booted again you can create a new instance for Satifactory. After this is installed you will see that it has set up the TCP and UDP correctly.
