Startup Issue with Satisfactory - Starting instance is in installing components loop
Application Satisfactory
Instance loops in “Application State: Installating Components” and don’t start although everything is alreay updated and installed correctly.
  • Login
  • Actions
  • Start
Logs:
Steam Console Client (c) Valve Corporation - version 1700160359
-- type 'quit' to exit --
15:40:42
Loading Steam API...dlmopen steamservice.so failed: steamservice.so: cannot open shared object file: No such file or directory
OK
force_install_dir 1690800
15:40:43
15:40:54
Waiting for user info...OK
app_update 1690800 validate
15:41:11
Update state (0x5) verifying install, progress: 0.14 (7340032 / 5156405293)
15:41:13
Update state (0x5) verifying install, progress: 14.13 (728491053 / 5156405293)
15:41:15
Update state (0x5) verifying install, progress: 38.01 (1959753720 / 5156405293)
15:41:17
Update state (0x5) verifying install, progress: 61.25 (3158419076 / 5156405293)
15:41:19
Update state (0x5) verifying install, progress: 85.25 (4395608065 / 5156405293)
15:41:20
Success! App '1690800' fully installed.
quit
15:41:21
15:41:22
OK
15:41:24
15:41:25
15:41:27
Update state (0x5) verifying install, progress: 14.96 (771173465 / 5156405293)
15:41:29
Update state (0x5) verifying install, progress: 38.52 (1986004236 / 5156405293)
15:41:31
Update state (0x5) verifying install, progress: 61.92 (3192614449 / 5156405293)
15:41:33
Update state (0x5) verifying install, progress: 85.88 (4428494893 / 5156405293)
15:41:34
quit
15:41:35
15:45:01
15:45:02
OK
15:45:03
15:45:04
Update state (0x5) verifying install, progress: 0.04 (2097152 / 5156405293)
15:45:06
Update state (0x5) verifying install, progress: 13.05 (672848487 / 5156405293)
15:45:08
Update state (0x5) verifying install, progress: 37.09 (1912469755 / 5156405293)
15:45:10
Update state (0x5) verifying install, progress: 61.17 (3154271528 / 5156405293)
15:45:12
Update state (0x5) verifying install, progress: 84.71 (4368053723 / 5156405293)
15:45:13
quit
15:45:14
15:45:15
OK
15:45:17
15:45:18
Update state (0x5) verifying install, progress: 0.08 (4194304 / 5156405293)
15:45:20
Update state (0x5) verifying install, progress: 18.56 (956833938 / 5156405293)
15:45:22
Update state (0x5) verifying install, progress: 42.30 (2180905080 / 5156405293)
15:45:24
Update state (0x5) verifying install, progress: 66.23 (3414949852 / 5156405293)
15:45:26
Update state (0x5) verifying install, progress: 89.53 (4616498077 / 5156405293)
quit```
Right click on your instance, Refresh Configuration to get the latest template
