Startup Issue with Satisfactory - Crash loop on startup
Product AMP ‘Callisto’ v2.5.0.12 (Mainline)
Application Satisfactory
About to restore ~3 day old backup but not sure if you have a better option and/or want the crashing save I took just before restarting.
  • After placing a blueprint into the designer client was disconnected
  • Took backup then restarted server
  • Server now saturates RAM on startup, then crashes
I have the same problem, but i can’t even start a save or upload one it crash before it load
The issue might be because of an update.
The satisfactory devs recommend starting a new world with the v1.0 update. So delete the old saves
For me, it was a save after 1.0 and I can’t start a new save, it’s the same problem.
Are you using Proxmox on the host?
No but i solve the problem, i had no swap with my vps, so i add 10gb.
