Startup Issue with Satisfactory - Application stopped unexpectedly with exit code 132
Application Satisfactory
I have tried removing instance, updating ampinstmgr / upgrade instances , create new instance with no luck
  • create instance
  • Insert Token
  • “update” / download server files
  • start server
OS Linux
Platform Debian GNU/Linux 12
System Type x86_64
CPU Model AMD Phenom™ II X6 1055T Processor
CPU Layout 1S/5C/5T
Installed RAM 17964
Module Application Satisfactory
Loaded Plugins FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin
Application Name AMP
Application Version 2.5.0.0
Codename Callisto
Tools Version 2.5
Release Stream Mainline
Build Spec Release
Build Date 15/03/2024 19:18
InstanceID 9d3d20af-46e4-4ede-b1f9-ce011ab25ab0
Last Executable /AMP/satisfactory/1690800/Engine/Binaries/Linux/UnrealServer-Linux-Shipping
Last Arguments FactoryGame -MultiHome=192.168.1.17 -Port=7777 -BeaconPort=15000 -ServerQueryPort=15777 -ini:Game:[/Script/Engine.GameSession]:MaxPlayers=4 -ini:Engine:[/Script/OnlineSubsystemUtils.IpNetDriver]:InitialConnectTimeout=30 -ini:Engine:[/Script/OnlineSubsystemUtils.IpNetDriver]:ConnectionTimeout=20 -ini:Engine:[/Script/OnlineSubsystemUtils.IpNetDriver]:NetServerMaxTickRate=30 -ini:Engine:[/Script/OnlineSubsystemUtils.IpNetDriver]:LanServerMaxTickRate=30 -ini:Engine:[/Script/SocketSubsystemEpic.EpicNetDriver]:NetServerMaxTickRate=30 -ini:Engine:[/Script/SocketSubsystemEpic.EpicNetDriver]:LanServerMaxTickRate=30 -ini:Engine:[/Script/Engine.Engine]:NetClientTicksPerSecond=30 -ini:Engine:[/Script/FactoryGame.FGSaveSession]:mNumRotatingAutosaves=3 -ini:Engine:[CrashReportClient]:bImplicitSend=True -log -unattended
Last Process ID 87
