| Product | AMP ‘Callisto’ v2.5.0.0 (Mainline) |
| Virtualization | VMware |
| Application | Satisfactory |
| Module | GenericModule |
| Running in Container | No |
| Current State | Stopped |
Installed instance fresh after previous server failed to start following AMP update. Set instance to update and start. While server attempts to load initial modules during start, server terminates itself and begins auto shutdown of server at which point amp tries to restart which yields the same results.
- Logged into amp and created a new server instance of satisfactory
- initially configured instance in the create instance dialog to automatically update and start upon boot
- selected manage instance and saw server was boot cycling. Viewed the console and saw where the server was attempting to boot normally, and at a point started it’s shutdown routines
Console log:
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Bridge/Content/' mounted to '/Bridge/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Compositing/LensDistortion/Content/' mounted to '/LensDistortion/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Compositing/OpenColorIO/Content/' mounted to '/OpenColorIO/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Developer/AnimationSharing/Content/' mounted to '/AnimationSharing/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Developer/Concert/ConcertSync/ConcertSyncClient/Content/' mounted to '/ConcertSyncClient/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/BlueprintHeaderView/Content/' mounted to '/BlueprintHeaderView/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/ConsoleVariablesEditor/Content/' mounted to '/ConsoleVariables/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/GeometryMode/Content/' mounted to '/GeometryMode/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/ObjectMixer/LightMixer/Content/' mounted to '/LightMixer/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/ObjectMixer/ObjectMixer/Content/' mounted to '/ObjectMixer/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/SpeedTreeImporter/Content/' mounted to '/SpeedTreeImporter/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Enterprise/DatasmithContent/Content/' mounted to '/DatasmithContent/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Enterprise/GLTFExporter/Content/' mounted to '/GLTFExporter/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosCaching/Content/' mounted to '/ChaosCaching/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosClothEditor/Content/' mounted to '/ChaosClothEditor/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosNiagara/Content/' mounted to '/ChaosNiagara/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosSolverPlugin/Content/' mounted to '/ChaosSolverPlugin/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosVehiclesPlugin/Content/' mounted to '/ChaosVehiclesPlugin/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ControlFlows/Content/' mounted to '/ControlFlows/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/Dataflow/Content/' mounted to '/Dataflow/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/FullBodyIK/Content/' mounted to '/FullBodyIK/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/GeometryCollectionPlugin/Content/' mounted to '/GeometryCollectionPlugin/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/GeometryScripting/Content/' mounted to '/GeometryScripting/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/Landmass/Content/' mounted to '/Landmass/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/PythonScriptPlugin/Content/' mounted to '/PythonScriptPlugin/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/UVEditor/Content/' mounted to '/UVEditor/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/FX/Niagara/Content/' mounted to '/Niagara/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Media/MediaCompositing/Content/' mounted to '/MediaCompositing/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Media/MediaPlate/Content/' mounted to '/MediaPlate/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/MovieScene/MovieRenderPipeline/Content/' mounted to '/MovieRenderPipeline/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/MovieScene/SequencerScripting/Content/' mounted to '/SequencerScripting/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/AudioSynesthesia/Content/' mounted to '/AudioSynesthesia/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/AudioWidgets/Content/' mounted to '/AudioWidgets/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/GeometryProcessing/Content/' mounted to '/GeometryProcessing/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/MeshModelingToolset/Content/' mounted to '/MeshModelingToolset/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/Metasound/Content/' mounted to '/Metasound/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/ResonanceAudio/Content/' mounted to '/ResonanceAudio/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/Synthesis/Content/' mounted to '/Synthesis/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/WaveTable/Content/' mounted to '/WaveTable/'
LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Tests/EditorTests/Content/' mounted to '/EditorTests/'
00:40:48
LogUObjectArray: 6148 objects are not in the root set, but can never be destroyed because they are in the DisregardForGC set.
LogUObjectAllocator: 12470904 out of 0 bytes used by permanent object pool.
LogUObjectArray: CloseDisregardForGC: 38893/38893 objects in disregard for GC pool
LogEngine: Initializing Engine...
LogContentBundle: [CB: TestContentBundle] Client Created
LogContentBundle: [CB: TestContentBundle] Client State changing from Unregistered to Registered
LogContentBundle: [Client] New client registered. Client: FGWorldPartitionContentBundleSubsystem, Descriptor: TestContentBundle
LogContentBundle: [CB: TestContentBundle] Client State changing from Registered to ContentInjectionRequested
LogContentBundle: [Client] Client requested content injection. Client: FGWorldPartitionContentBundleSubsystem, Descriptor: TestContentBundle
LogAssetManager: Display: Ignoring PrimaryAssetType Profiling - Conflicts with Map - Asset: Map_UI-Profile
LogInit: Initializing FReadOnlyCVARCache
LogNetVersion: Set ProjectVersion to 0.0.1.0. Version Checksum will be recalculated on next use.
LogInit: Texture streaming: Disabled
LogUserSetting: Initializing user settings
LogSynthBenchmark: Display: FSynthBenchmark (V0.95): requested WorkScale=10.00
LogSynthBenchmark: Display: ===============
LogSynthBenchmark: Display: Main Processor:
LogSynthBenchmark: Display: ... 0.011136 s/Run 'RayIntersect'
LogSynthBenchmark: Display: ... 0.016131 s/Run 'Fractal'
LogSynthBenchmark: Display: CompiledTarget_x_Bits: 64
LogSynthBenchmark: Display: UE_BUILD_SHIPPING: 1
LogSynthBenchmark: Display: UE_BUILD_TEST: 0
LogSynthBenchmark: Display: UE_BUILD_DEBUG: 0
LogSynthBenchmark: Display: TotalPhysicalGBRam: 16
LogSynthBenchmark: Display: NumberOfCores (physical): 8
LogSynthBenchmark: Display: NumberOfCores (logical): 8
LogSynthBenchmark: Display: CPU Perf Index 0: 230.0 (weight 1.00)
LogSynthBenchmark: Display: CPU Perf Index 1: 177.3 (weight 1.50)
LogSynthBenchmark: Display: Graphics:
LogSynthBenchmark: Display: Adapter Name: ''
LogSynthBenchmark: Display: (On Optimus the name might be wrong, memory should be ok)
LogSynthBenchmark: Display: Vendor Id: 0x1
LogSynthBenchmark: Display: Device Id: 0x0
LogSynthBenchmark: Display: Device Revision: 0x0
LogSynthBenchmark: Display: CPUIndex: 198.4
LogSynthBenchmark: Display: ... Total Time: 0.272723 sec
LogWwiseSoundEngine: Display: Loading Wwise Sound Engine version 2022.1
LogModuleManager: Shutting down and abandoning module NiagaraAnimNotifies (160)
LogModuleManager: Shutting down and abandoning module Niagara (158)
LogModuleManager: Shutting down and abandoning module SignalProcessing (157)
LogModuleManager: Shutting down and abandoning module NiagaraCore (154)
LogModuleManager: Shutting down and abandoning module GeometryScriptingCore (152)
LogModuleManager: Shutting down and abandoning module PBIK (150)
LogModuleManager: Shutting down and abandoning module FullBodyIK (148)
LogModuleManager: Shutting down and abandoning module ChaosVehicles (146)
LogModuleManager: Shutting down and abandoning module ChaosCaching (144)
LogModuleManager: Shutting down and abandoning module EnhancedInput (142)
LogModuleManager: Shutting down and abandoning module FacialAnimation (140)
LogModuleManager: Shutting down and abandoning module AnimationSharing (138)
LogModuleManager: Shutting down and abandoning module GameplayCameras (136)
LogModuleManager: Shutting down and abandoning module IKRig (134)
LogModuleManager: Shutting down and abandoning module ControlRig (132)
LogModuleManager: Shutting down and abandoning module Constraints (131)
LogModuleManager: Shutting down and abandoning module LevelSequence (129)
LogModuleManager: Shutting down and abandoning module Paper2D (126)
LogModuleManager: Shutting down and abandoning module Wwise (124)
LogModuleManager: Shutting down and abandoning module AndroidFileServer (122)
LogModuleManager: Shutting down and abandoning module NetworkReplayStreaming (120)
LogModuleManager: Shutting down and abandoning module PacketHandler (118)
LogModuleManager: Shutting down and abandoning module ClothingSystemRuntimeNv (116)
LogModuleManager: Shutting down and abandoning module MediaAssets (114)
LogModuleManager: Shutting down and abandoning module Messaging (112)
LogModuleManager: Shutting down and abandoning module Networking (110)
LogModuleManager: Shutting down and abandoning module Core (108)
LogModuleManager: Shutting down and abandoning module Media (106)
LogModuleManager: Shutting down and abandoning module NullDrv (102)
LogModuleManager: Shutting down and abandoning module ChaosSolverEngine (100)
LogModuleManager: Shutting down and abandoning module FieldSystemEngine (99)
LogModuleManager: Shutting down and abandoning module Chaos (96)
LogModuleManager: Shutting down and abandoning module GeometryCore (95)
LogModuleManager: Shutting down and abandoning module OnlineIntegration (92)
LogModuleManager: Shutting down and abandoning module OnlineServicesSteamLimited (91)
LogModuleManager: Shutting down and abandoning module SteamShared (90)
LogSteamShared: Freeing the Steam Loaded Modules...
LogModuleManager: Shutting down and abandoning module NISBlueprint (85)
LogModuleManager: Shutting down and abandoning module NISShaders (83)
LogModuleManager: Shutting down and abandoning module DLSSBlueprint (81)
00:40:49
LogModuleManager: Shutting down and abandoning module HTTP (66)
LogModuleManager: Shutting down and abandoning module SSL (65)
LogModuleManager: Shutting down and abandoning module OnlineSubsystemUtils (61)
LogModuleManager: Shutting down and abandoning module OnlineServicesCommonEngineUtils (59)
LogModuleManager: Shutting down and abandoning module OnlineServicesCommon (57)
LogModuleManager: Shutting down and abandoning module OnlineServicesOSSAdapter (55)
LogModuleManager: Shutting down and abandoning module OnlineServicesEOS (53)
LogModuleManager: Shutting down and abandoning module OnlineServicesEOSGS (51)
LogModuleManager: Shutting down and abandoning module OnlineServicesInterface (50)
LogModuleManager: Shutting down and abandoning module EOSShared (47)
LogEOSSDK: LogEOS: SDK Config Platform Update Request Successful, Time: 1.617312
LogEOSSDK: LogEOS: Updating Product SDK Config, Time: 1.617560
LogEOSSDK: LogEOS: SDK Config Product Update Request Successful, Time: 1.834596
LogEOSSDK: LogEOS: SDK Config Data - Watermark: -341829651
LogEOSSDK: LogEOS: ScheduleNextSDKConfigDataUpdate - Time: 1.834596, Update Interval: 358.918213
LogEOSSDK: FEOSSDKManager::Shutdown EOS_Shutdown Result=[EOS_Success]
LogModuleManager: Shutting down and abandoning module NiagaraVertexFactories (45)
LogModuleManager: Shutting down and abandoning module NiagaraShader (43)
LogModuleManager: Shutting down and abandoning module ChaosCloth (41)
LogModuleManager: Shutting down and abandoning module VariantManagerContent (39)
LogModuleManager: Shutting down and abandoning module GLTFExporter (37)
LogModuleManager: Shutting down and abandoning module DatasmithContent (35)
LogModuleManager: Shutting down and abandoning module OpenColorIO (33)
LogModuleManager: Shutting down and abandoning module LensDistortion (31)
LogModuleManager: Shutting down and abandoning module AISupportModule (29)
LogModuleManager: Shutting down and abandoning module PythonScriptPluginPreload (27)
LogModuleManager: Shutting down and abandoning module PlatformCryptoOpenSSL (25)
LogModuleManager: Shutting down and abandoning module PlatformCryptoTypes (23)
LogModuleManager: Shutting down and abandoning module PlatformCrypto (21)
LogModuleManager: Shutting down and abandoning module RenderCore (19)
LogModuleManager: Shutting down and abandoning module Landscape (16)
LogModuleManager: Shutting down and abandoning module AnimGraphRuntime (14)
LogModuleManager: Shutting down and abandoning module Renderer (12)
LogModuleManager: Shutting down and abandoning module Engine (10)
LogModuleManager: Shutting down and abandoning module CoreUObject (8)
LogModuleManager: Shutting down and abandoning module SandboxFile (6)
LogModuleManager: Shutting down and abandoning module PakFile (4)
LogModuleManager: Shutting down and abandoning module RSA (3)
LogExit: Exiting.
Shutdown handler: cleanup.
