Startup Issue with Rust Dedicated Server - Instance is locked in Installing Components
Application Rust Dedicated Server
Module RustModule
Current State Installing
Unable to get instance to complete installing components
  • Attempted to abort the update and just start up normally. Fails.
  • I have restarted the instance a number of times and same result.
  • Reviewed logs and I dont see where it is failing. No clear errors
Log report
[08:25:30] [Program Info/1] : Starting AMP version 2.6.0.6 (Phobos), built 20/11/2024 20:57
[08:25:30] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[08:25:30] [Program Info/1] : Running in a Docker environment.
[08:25:30] [Program Info/1] : OS: Linux / x86_64
[08:25:30] [Program Info/1] : CPU: QEMU Virtual CPU version 2.5+ (24C/1T)
[08:25:30] [Program Info/1] : RAM: 129815MB
[08:25:30] [Program Info/1] : AMP Instance ID: ********************************
[08:25:31] [Core Info/1] : Loaded RustModule version 2.6.0.6 by CubeCoders Limited
[08:25:31] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[08:25:31] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[08:25:31] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[08:25:31] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[08:25:31] [FileBackup Info/1] : Found orphaned backup file 20250110-081134-3bdca5d12ba74b57a45b9297043ca35d.zip in backup store. Adding…
[08:25:31] [FileBackup Warning/1] : Backup 20250110-081134-3bdca5d12ba74b57a45b9297043ca35d.zip is missing a manifest entry. Skipping…
[08:25:31] [FileBackup Warning/1] : 20250110-081134-3bdca5d12ba74b57a45b9297043ca35d.zip is missing a manifest entry. Skipping…
[08:25:31] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[08:25:31] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[08:25:32] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[08:25:32] [System Error/9] : Missing plugin/assembly: MaxMind.Db (/AMP/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[08:25:32] [Loader Info/1] : RustModule requests dependency steamcmdplugin…
[08:25:32] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[08:25:32] [Loader Info/1] : RustModule requests dependency RCONPlugin…
[08:25:32] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[08:25:32] [Core Info/1] : Licence Present: AMP Standard Edition - Lifetime Licence
[08:25:32] [Loader Notice/1] : Using keypair with fingerprint ticCJwTkRBQo7gcQvvPT1RkwaIceMFGSaLRz/xBr040=
[08:25:32] [Loader Info/1] : SFTP Server started on 0.0.0.0:2224
[08:25:34] [Core Info/1] : Webserver started on http://127.0.0.1:8081
[08:25:34] [System Info/12] : Startup mode is UpdateAndStart.
[08:25:34] [System Info/9] : Checking for AMP updates…
[08:25:35] [System Info/12] : AMP is up to date.
[09:41:00] [System Info/33] : Checking for AMP updates…
[09:41:00] [System Info/33] : AMP is up to date.
[15:41:00] [System Info/31] : Checking for AMP updates…
[15:41:01] [System Info/48] : AMP is up to date.
[16:03:20] [System Activity/41] : Authentication attempt for user amp from 127.0.0.1
[16:03:20] [System Activity/41] : Authentication success
