Startup Issue with Project Zomboid - Server stuck in Starting status
Application Project Zomboid
Current State Starting
I have another instance of the same game that starts/stops properly.
  • Start Server
  • Wait until it says started
  • The only action available is “Abort”
The server is waiting for you to create an admin password
Check the console
Not really, admin and rcon password are already set.
Make sure your instance template config is up to date, since you are running b42 and the logging changed
Click on the down arrow on the instance tile from the main instances page
(Makes it easier to troubleshoot when you provide some logging lol)
Thank you, that fixed it :slight_smile:
