Startup Issue with PixARK - Pixark is in "Starting" state
Product AMP ‘Phobos’ v2.6.0.10 (Mainline)
Application PixARK
Current State Starting
When starting PixARK server, then it’s progress gets “stuck” in “Startin PixARK…”. But actually server is running and I can join server. And after some time. AMP will tell that failed to start, but actually server is still accessible through multiplayer game. Any idea, why it is so? Can it be fixed somehow?
  • Update instance
  • start instance
  • gets stuck in “Starting” state
AMP marks the server as ready if it could connect to the RCON. So, something fails at that part.
Added in AMP to “Custom Command Line Options” RCON port aswell (even if AMP tells: “Don’t use options already in AMP’s settings!”), but with no success, still in “starting” state. Instance itself shows that all ports are “green” in “listening” state.
Any other ideas, what I can test?
Generate a new “remote admin password” and restart the server
Thnx @Greelan. I tried, and still in “starting” state…
