Startup Issue with Palworld - Unable to connect to Server
Application Palworld
Server would start, try to update, then fail.
Tried this a few times.
Restarted the instance.
Started again, went to update, failed.
Went to log into SFTP, refused connection.
Trying to get a copy of the save to at least play it locally.
Found an article that could have a solve to the issue. Looks like you need to add some file and it works. looks to be windows based, but could something similar work for linux?
  • Started the Server
  • Update the server
  • Server stopped
Same issue here, I updated to 2.5.0.4 with same issue. It looks like its updating successfully in the logs but everytime I start it downloads and installs again.
