Field
Value
Operating System
Product
AMP ‘Decadeus’ v2.4.8.0 (Mainline)
Virtualization
Docker
Application
Palworld
Module
GenericModule
Running in Container
Yes
Current State
Starting
I just updated the palworld server and now it doesn’t start, I don’t know what to do
start palworld server
press the update button
I tried to start the server again but it didn’t work
Greelan
February 27, 2024, 10:23am
2
Remove the instance from docker. Update the instance (not the server). Put the instance in docker again
thanks for your answer.
Could you explain to me a little better how to do that?
This is the first time I have used this system and I am not familiar with the operation of the system.
Greelan
February 27, 2024, 8:26pm
4
From the Main Menu screen (which shows all your instances):
Right click on the instance, Edit Settings, turn off “Run in Docker Container”. Save changes and wait until finished
Right click on the instance, Update. Wait until finished
Right click on the instance, Edit Settings, turn on “Run in Docker Container”. Save changes and wait until finished
Start the instance if not running, then Manage it
Find the “Community Server” setting, turn it off and on a couple of times
Done
