Startup Issue with Palworld - server crashes every 10 min
Application Palworld
i am getting logged out sometime there no response its lags too much even though there is too much space and and ram this should not be happening
  • well first i created the instances of game palworld in my first application and it keeps happening then i shut it down and started a new application after some time it started showing the same problem like crashes and stall then i upgraded the plan into more better plan thinking that might be the pressure that makes ther application crash but now even the server is empty it stills crashes
  • well i tried pausing it resetting it into its default setting with no modification turned on still the sam issue with the crashes the longest it has run is 3 hrs stright but then it just keep crashing and stalling another thing is ping i dont know why its some time show too much differnce in ping and status does not changes after running the application it just show starting and keep on showing the same thing till faliure
  • now i am resetting the server and then reboot the vps still no progress
