Startup Issue with Palworld - RCON Port not activating
Application Palworld
Current State Starting
for the past day whenever I try starting up the server it would always show the RCON Port as red and not activated. I have tried
  • restarting the server
  • turning off and on the instance
  • updating the server
however none of it worked, and causes the server to keep shutting down after 2 attempts of trying to start up. It became like this after the recent update
  • Update the Server
  • Restart the Server
  • Turn off and on the instance
@Luminoux This worked for me and it looks like others as well.
From Greelan - Startup Issue with Palworld - The server does not start - #2 by Greelan
"Greelan
6h
From the Main Menu screen (which shows all your instances):
Right click on the instance, Edit Settings
Turn off “Run in Docker Container”
Save changes. Wait until finished
Right click on the instance, Update. Wait until finished
Right click on the instance, Edit Settings, turn on “Run in Docker Container”. Save changes and wait until finished
Start the instance if not running, then Manage it
Find the “Community Server” setting, turn it off and on a couple of times
Done"
