| Product | AMP ‘Decadeus’ v2.4.8.0 (Mainline) |
| Virtualization | Docker |
| Application | Palworld |
| Module | GenericModule |
| Current State | PreStart |
When I start my Palworld Server Instance I get a permission error when starting and the application says that the server is in starting game app.
- Log into Hostinger VPS Game Panel
- Navigate to Palworld Server Instance
- Double click on Instance to manage it.
- Click Start on Instance
| OS | Linux |
| Platform | Debian GNU/Linux 11 |
| System Type | x86_64 |
| CPU Model | AMD EPYC 7543P 32-Core Processor |
| CPU Layout | 1S/4C/4T |
| Installed RAM | 16011 |
| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Module Application | Application Deployment |
| Loaded Plugins | FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin |
| Application Name | AMP |
| Application Version | 2.4.8.0 |
| Codename | Decadeus |
| Tools Version | 2.4.8 |
| Release Stream | Mainline |
| Build Spec | Release |
| Build Date | 29/01/2024 18:40 |
| InstanceID | 807be8d5-c68a-41ff-b8b8-0a126bf73389 |
| Last Executable | |
| Last Arguments | |
| Last Process ID | 1851 |
Logs
[23:47:31] [Core Info] : Starting AMP version 2.4.8.0 (Decadeus), built 29/01/2024 18:40
[23:47:31] [Core Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[23:47:31] [Logger Info] : Purging old audit logs (this may take a moment)…
[23:47:31] [Core Info] : Running in a Docker environment.
[23:47:31] [Core Info] : OS: Linux / x86_64
[23:47:31] [Core Info] : CPU: AMD EPYC 7543P 32-Core Processor (4C/4T)
[23:47:31] [Core Info] : RAM: 16011MB
[23:47:31] [Core Info] : AMP Instance ID: c9f9e6ed-4d64-48ae-9b16-90bff1fdd713
[23:47:32] [Loader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[23:47:32] [Core Info] : Metrics publishing is enabled at udp://82.197.92.150:12820.
[23:47:32] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[23:47:32] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[23:47:32] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[23:47:32] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[23:47:32] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[23:47:32] [Loader Info] : GenericModule requests dependency steamcmdplugin…
[23:47:32] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[23:47:32] [Loader Info] : GenericModule requests dependency RCONPlugin…
[23:47:32] [Loader Info] : Loaded RCONPlugin by CubeCoders Limited
[23:47:32] [Core Warning] : No such setting node: GenericModule.App.Ports. - maybe the relevant plugin/module isn’t loaded?
[23:47:32] [Core Info] : Licence Present: AMP Enterprise Edition
[23:47:38] [FileManager Notice] : Using keypair with fingerprint MUaNizL/YnNGrwlrTN7WsigXHKCFer/OLQ9Lu9Us89c=
[23:47:38] [FileManager Info] : SFTP Server started on 0.0.0.0:2224
[23:47:38] [Webserver Info] : Websockets are enabled.
[23:47:38] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[23:47:38] [Webserver Info] : Webserver started on http://0.0.0.0:8081
[23:47:38] [Core Info] : Checking for AMP updates…
[23:47:38] [Core Info] : Startup mode is StartApplication.
[23:47:42] [Generic Info] : Merging config file ./palworld/2394010/Pal/Saved/Config/WindowsServer/PalWorldSettings.ini (Template) using Unicode (UTF-8) encoding.
[23:47:42] [Core Error] : ArgumentNullException
[23:47:42] [Core Error] : [0] (ArgumentNullException) : Value cannot be null.
Parameter name: input
[23:47:42] [Core Error] : at Text.RegularExpressions.Regex.Replace (String input, Text.RegularExpressions.MatchEvaluator evaluator)
at GenericModule.GenericModuleConfig+ApplicationConfig.SubstituteTemplates (String input, Collections.Generic.Dictionary`2[TKey,TValue] variables)
at GenericModule.GenericModuleConfig+ApplicationConfig.GetValue (String input)
at GenericModule.ModuleMain.b__36_0 (Text.RegularExpressions.Match m)
at Text.RegularExpressions.Regex.Replace (Text.RegularExpressions.MatchEvaluator evaluator, Text.RegularExpressions.Regex regex, String input, Int32 count, Int32 startat)
at Text.RegularExpressions.Regex.Replace (String input, Text.RegularExpressions.MatchEvaluator evaluator, Int32 count, Int32 startat)
at GenericModule.ModuleMain.MergeTemplate (String finalPath, GenericModule.MetaConfigFile fileInfo)
at GenericModule.ModuleMain.MergeConfigFile (String finalPath, GenericModule.MetaConfigFile fileInfo)
at GenericModule.ModuleMain.WriteMetaconfigs ()
at GenericModule.ModuleMain.SaveChanges (String key, String value)
at GenericModule.GenericApp.DoAppStartup (Boolean IsUpdating)
at GenericModule.GenericApp.Start ()
[23:47:43] [Core Activity] : Authentication attempt for user admin from 127.0.0.1
[23:47:44] [Core Activity] : Authentication success
[23:47:44] [Core Info] : AMP is up to date.
