Startup Issue with Palworld - it keeps crashing with ue4ss
Operating System Windows - Windows Server 2025 on x86_64
Virtualization Xen
Application Palworld
i removed mods and it boots fine but when i use modded version it doesn’t want to boot after latest palworld patch
Palworld dump crash file: https://github.com/user-attachments/files/24840424/crash_2026_01_24_17_29_53.9269658.dmp
  • Removed ue4ss
  • Installed ue4ss manually same issue
  • reinstalled and updated and redone the whole server same problem
Update your instances by clicking on the down arrow on the instance tile on the main page, to refresh their config
I tried this but get the same error where it starts but then crashes ue4ss but i used another program and it works fine but i want to use AMP Instance Manager for the program - well this time it worked i tried this before and it didn’t work but it works now not sure what was going on but thank you for the help
