| Field |
Value |
| Operating System |
Windows - Windows 10 Pro on x86_64 |
| Product |
AMP ‘Phobos’ v2.6.2.2 (Mainline) |
| Virtualization |
None |
| Application |
Node.js App Runner |
| Module |
GenericModule |
| Running in Container |
No |
| Current State |
Updating |
The reproduction steps are all I did. Using Node.js App runner with reccommended installation, fresh installation of AMP
- Create Instance
- Set github download token and link
- Boot up application
You are going to have to provide more information regarding your download settings if you want any help
Yeah, it wouldnt let me post them until someone else responded.
CONSOLE LOG
Installing the app
Cloning into ‘srv’…
Yes, the token is valid
Other config
Passthru Protocol
The RCON protocol to be emulated
Source RCON
Passthru IP Binding
Which IP address should be used for the passthru Server
127.0.0.1 (IPv4 Loopback)
Passthru Port
Which Port should be used for the Passthru Server
7777
TCP
Not the App tab, the Download tab
yep, again it would only let me post 1 image, all it is is a link and a token (which is correct)
You also need to include the username in the Git Repo Username box
system
Closed
7
