Field | Value |
Product | AMP ‘Callisto’ v2.5.0.4 (Mainline) |
Virtualization | Docker |
Application | No One Survived |
Module | GenericModule |
Running in Container | Yes |
Current State | Starting |
Server starts to load but then gets stuck at “[2024.04.10-07.01.33:352][267]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Certificate expires in 46h20m at 1712899293 (current time 1712732492), will renew in 44h20m”
- Startup Server
- Delete and recreate instance
- Check network configuration settings
Log:
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk19-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk19-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Newmap/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk18-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk18-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk18-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Newmap/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk17-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk17-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk17-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/Scence/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk16-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk16-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk16-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/Scence/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk15-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk15-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk15-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/Scence/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk14-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk14-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk14-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/Scence/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk13-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk13-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk13-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/Scence/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk12-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk12-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk12-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/Scence/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk11-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk11-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk11-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/Scence/Safe_House/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk10-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk10-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk10-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/Mesh/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk1-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk1-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk1-WindowsServer.pak’, mount point: ‘…/…/…/WRSH/Content/’
LogPakFile: Display: Found Pak file …/…/…/WRSH/Content/Paks/pakchunk0-WindowsServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/WRSH/Content/Paks/pakchunk0-WindowsServer.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/WRSH/Content/Paks/pakchunk0-WindowsServer.pak’, mount point: ‘…/…/…/’
10:04:09
LogStats: Stats thread started at 0.360406
LogICUInternationalization: ICU TimeZone Detection - Raw Offset: +0:00, Platform Override: ‘’
LogInit: Session CrashGUID >====================================================
Session CrashGUID > UECC-Windows-A7235BEE4930A4AA305B9A8B587627B1
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Editor/UVEditor/Content/’ mounted to ‘/UVEditor/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Enterprise/DatasmithContent/Content/’ mounted to ‘/DatasmithContent/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Enterprise/GLTFExporter/Content/’ mounted to ‘/GLTFExporter/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosCaching/Content/’ mounted to ‘/ChaosCaching/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosClothEditor/Content/’ mounted to ‘/ChaosClothEditor/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosNiagara/Content/’ mounted to ‘/ChaosNiagara/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosSolverPlugin/Content/’ mounted to ‘/ChaosSolverPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosVehiclesPlugin/Content/’ mounted to ‘/ChaosVehiclesPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/Dataflow/Content/’ mounted to ‘/Dataflow/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/FullBodyIK/Content/’ mounted to ‘/FullBodyIK/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/GeometryCollectionPlugin/Content/’ mounted to ‘/GeometryCollectionPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/GeometryFlow/Content/’ mounted to ‘/GeometryFlow/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/GeometryScripting/Content/’ mounted to ‘/GeometryScripting/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/Landmass/Content/’ mounted to ‘/Landmass/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/MeshLODToolset/Content/’ mounted to ‘/MeshLODToolset/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/PCGGeometryScriptInterop/Content/’ mounted to ‘/PCGGeometryScriptInterop/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/PCG/Content/’ mounted to ‘/PCG/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/PythonScriptPlugin/Content/’ mounted to ‘/PythonScriptPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/StaticMeshEditorModeling/Content/’ mounted to ‘/StaticMeshEditorModeling/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ToolPresets/Content/’ mounted to ‘/ToolPresets/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/VirtualHeightfieldMesh/Content/’ mounted to ‘/VirtualHeightfieldMesh/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/Water/Content/’ mounted to ‘/Water/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/FX/Niagara/Content/’ mounted to ‘/Niagara/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Fab/Content/’ mounted to ‘/Fab/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Interchange/Runtime/Content/’ mounted to ‘/Interchange/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Media/MediaCompositing/Content/’ mounted to ‘/MediaCompositing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Media/MediaPlate/Content/’ mounted to ‘/MediaPlate/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/MovieScene/SequencerScripting/Content/’ mounted to ‘/SequencerScripting/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/AudioSynesthesia/Content/’ mounted to ‘/AudioSynesthesia/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/AudioWidgets/Content/’ mounted to ‘/AudioWidgets/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/GeometryProcessing/Content/’ mounted to ‘/GeometryProcessing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/HairStrands/Content/’ mounted to ‘/HairStrands/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/MeshModelingToolset/Content/’ mounted to ‘/MeshModelingToolset/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Metasound/Content/’ mounted to ‘/Metasound/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/ResonanceAudio/Content/’ mounted to ‘/ResonanceAudio/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/RigVM/Content/’ mounted to ‘/RigVM/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Synthesis/Content/’ mounted to ‘/Synthesis/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/WaveTable/Content/’ mounted to ‘/WaveTable/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/TraceUtilities/Content/’ mounted to ‘/TraceUtilities/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/VirtualProduction/Takes/Content/’ mounted to ‘/Takes/’
10:04:10
Setting breakpad minidump AppID = 1963370
[2024.04.10-07.04.10:258][ 0]LogMemory: Platform Memory Stats for WindowsServer
[2024.04.10-07.04.10:258][ 0]LogMemory: Process Physical Memory: 499.60 MB used, 499.60 MB peak
[2024.04.10-07.04.10:258][ 0]LogMemory: Process Virtual Memory: 475.20 MB used, 475.20 MB peak
[2024.04.10-07.04.10:258][ 0]LogMemory: Physical Memory: 5416.67 MB used, 14576.89 MB free, 19993.55 MB total
[2024.04.10-07.04.10:259][ 0]LogMemory: Virtual Memory: 6835.92 MB used, 23397.63 MB free, 30233.55 MB total
10:04:25
[2024.04.10-07.04.25:680][ 5]LogSteamSocketsAPI: Warning: SteamSockets API: Warning SDR network config fetch first attempt failed. HTTP 504. . Trying again.
10:04:29
[2024.04.10-07.04.29:648][ 7]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Got SDR network config. Loaded revision 1712342031 OK
[2024.04.10-07.04.29:648][ 7]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Performing ping measurement
[2024.04.10-07.04.29:648][ 7]LogSteamSocketsAPI: Verbose: SteamSockets API: Log SDR RelayNetworkStatus: avail=Attempting config=OK anyrelay=Attempting (Performing ping measurement)
[2024.04.10-07.04.29:648][ 7]r.VolumetricCloud.DistanceToSampleMaxCount = “3.1”
[2024.04.10-07.04.29:649][ 7]r.VolumetricRenderTarget.Mode = “2”
[2024.04.10-07.04.29:649][ 7]r.EyeAdaptation.BlackHistogramBucketInfluence = “0.5”
[2024.04.10-07.04.29:723][ 7]net.UseAdaptiveNetUpdateFrequency = “1”
10:04:30
[2024.04.10-07.04.30:427][ 28]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Ping measurement completed
[2024.04.10-07.04.30:427][ 28]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Ping location: fra=30+3,ams=37+3,par=38+3,vie=40+4/41+3,lhr=43+4/42+3,waw=46+4/46+3,sto=51+5/49+3,sto2=51+5/49+3,mad=62+6/57+3,iad=120+12/115+3,sgp=202+20/198+14,gru=223+22
[2024.04.10-07.04.30:427][ 28]LogSteamSocketsAPI: Verbose: SteamSockets API: Log SDR RelayNetworkStatus: avail=OK config=OK anyrelay=OK (OK)
10:04:34
[2024.04.10-07.04.34:029][ 91]t.MaxFPS = “30”
10:04:35
[2024.04.10-07.04.35:153][126]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Gameserver logged on to Steam, assigned identity steamid:90196498499981339
[2024.04.10-07.04.35:153][126]LogSteamSocketsAPI: Verbose: SteamSockets API: Log AuthStatus (steamid:90196498499981339): Attempting (Requesting cert)
[2024.04.10-07.04.35:153][126]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Set SteamNetworkingSockets P2P_STUN_ServerList to ‘162.254.197.54:3478’ as per SteamNetworkingSocketsSerialized
[2024.04.10-07.04.35:430][134]LogSteamSocketsAPI: Verbose: SteamSockets API: Log AuthStatus (steamid:90196498499981339): OK (OK)
[2024.04.10-07.04.35:430][134]LogSteamSocketsAPI: Verbose: SteamSockets API: Log Certificate expires in 48h00m at 1712905475 (current time 1712732674), will renew in 46h00m
