| Field |
Value |
| Operating System |
Linux - Ubuntu 24.04.4 on x86_64 |
| Product |
AMP ‘Proteus’ v2.8.0.4 (Mainline) |
| Virtualization |
None |
| Application |
Mount & Blade II: Bannerlord |
| Module |
GenericModule |
| Running in Container |
No |
| Current State |
Failed |
“Unable to run” can’t find further information.
- Install official instance
- install required library
- “Unable to Run”
I have not tried this, but did you actually install the server software? Per this below it looks like you have to do that step separately.
Yes I have the token, and I did also attempt to manually port over server files instead of relying on those auto-downloaded by the preset (though far as I can tell, the auto-downloaded files are 1:1 the dedicated server files directly available from talewords)
So not quite sure what the issue is. No logs or console I can find anywhere mention the issue either.
WHen you click start, what is showing in the console?
Console does nothing, I unplugged my server for the moment, but it was either the start of normal bootup or entirely blank. No following errors, with the GUI saying “Unable to start” with a red question mark. Question mark links to I forget what at this exact moment, but another different console, I believe the AMP one - which also has no helpful information generally just the “starting instance” command with nothing following.
Look in file manager and under the folder Amp Logs…that is about all I have left to recommend. At a loss on this otherwise.
Run the instance in docker
