Startup Issue with Mount & Blade II: Bannerlord - Mount & Blade: Bannerlord Dedicated Server won’t start
Application Mount & Blade II: Bannerlord
Hello,
I followed the official TaleWorlds tutorial for setting up a Mount & Blade: Bannerlord Dedicated Server.
However, the server won’t start at all with or without my custom config.
Every time I click “Start Instance” it immediately shuts down again.
Could you please help me identify why the Bannerlord server is closing instantly on startup?
Thank you!
  • Enterd the Auth Token
  • imported a custom config file in Modules/Native
  • editet the custom config file (its called tdm_config.txt)
  • set the config file as the server configuration file to load from the ‘Modules/Native’ directory
  • and started the server
