Startup Issue with Miscreated - The server won't start
Operating System Windows - Windows Server 2019 on x86_64
Virtualization HyperV
Application Miscreated
Current State Starting
After installation, a window with messages appears at the bottom that says “Starting Miscreated,” but nothing happens. There are also no errors visible in the logs.
Unloading Steam API...OK
CPID: 2704
Redirecting stderr to 'C:\AMPDatastore\Instances\OldbMisty01\miscreated\logs\stderr.txt'
Logging directory: 'C:\AMPDatastore\Instances\OldbMisty01\miscreated/logs'
[  0%] Checking for available updates...
Steam Console Client (c) Valve Corporation - version 1788292693
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "302200"
Waiting for user info...OK
app_update 302200 validate
 Update state (0x5) verifying install, progress: 11.93 (547982515 / 4592284567)
 Update state (0x5) verifying install, progress: 29.22 (1342024379 / 4592284567)
 Update state (0x5) verifying install, progress: 45.65 (2096283580 / 4592284567)
 Update state (0x5) verifying install, progress: 63.73 (2926755772 / 4592284567)
 Update state (0x5) verifying install, progress: 79.17 (3635849275 / 4592284567)
 Update state (0x5) verifying install, progress: 99.10 (4550771221 / 4592284567)
 Update state (0x61) downloading, progress: 33.46 (26180048 / 78237701)
 Update state (0x61) downloading, progress: 98.40 (76986629 / 78237701)
 Update state (0x0) unknown, progress: 0.00 (0 / 0)
Success! App '302200' fully installed.
quit
 * created a new instance
 * I chose the game Miscreate
 * Everything was installed automatically without any errors
After the install/update, you need to go back to the instance screen and start the server:
Thanks for the reply. The problem is that it won’t start. I’m not getting any error messages, not even in the logs.
I noticed when I installed Miscreated with the default template it was really laggy. You might try loading Greelan’s template instead. It is under the overall AMP configuration, add his github and do a template update to load them.
Greelan/AMPTemplates:dev
Then you can set up a new instance using his Miscreated template. It seemed much better, so I am not sure what is wrong with the base one.
Thanks for the quick response.
I’ve now set up two Git sources. When creating a miscreated instance, how can I choose which source it should use?
Or do I have to delete the other one?
Don’t delete the other… it is the main amp one.
When you create an instance from the main menu and are picking the game, pick the one named Greelan/Miscreated. Both repositories are shown in the list.
