Startup Issue with Minecraft - Won't launch, amp error
Current State Starting
LIM - Failure to make API call to Prominence201: Connection refused (127.0.0.1:8082)
  • fixed fabric in files
  • fixed fabric in config
  • removed incompatible mods
Press the folder icon on the effected instance, then read it’s latest log from under AMP_Logs
Hi, so the log is now just repeating this error a bunch of times and still contains the LIM failure in the beginning, i tried restarting and updating
That means the session in your browser is stale, use Ctrl+F5 to force-refresh
Okay, and when trying to put a mod in the mods folder it says uploading gives me a check mark and then doesn’t actually upload it, the instance isn’t running either :confused:
refreshed and got this
Try uploading the mod(s) over SFTP instead.
And check the AMP Logs for further info (file icon → AMP_Logs folder).
