Startup Issue with Minecraft - Won't boot newest version of Minecraft
The newest version of Minecraft Java Edition will not start. If I revert the instance to the second newest release (1.21.11), it will boot. Whereas, when I change it back, it still won’t load. I get a message saying it isn’t the amp panel because it fails to load within the first 5 seconds. Also saying to check the server logs to see why it is happening, but it is only happening to this version of Minecraft.
  • Create New Instance
  • Select Minecraft Java
  • Finish the instance and let it try to start up
