Startup Issue with Minecraft - when i tried to join server, the world not displayed
and the cpu usage goes to 100% and 0%
  • starting server and can’t play
  • when it starting
  • the server restarting again
Be sure to read the log to see what happened
it says:
Server thread/WARN
Can’t keep up! Is the server overloaded? Running 45532ms or 910 ticks behind
That means the server has a lot going on, caused by world generation, mobs, or mods.
fyi i have villager breeder, does this have any effect?
No idea, you’d need to run a profiler using the Spark plugin/mod and that would tell you what’s overutilizing the CPU.
If you can’t figure it out you could also revert to a previous backup if you set that up.
