Startup Issue with Minecraft - URL cannot be determined
Current State Installing
I’m trying to get forge 47.1.3 up and running but when I try to start the server I always get a “URL cannot be determined” error
  • select forge 47.1.3
  • update
  • start
  • select jdk17
Just a sanity check, the Jar has been left as “Autoselect”?
If so could you right click the instance from the main panel, hit “View logs”, then share that?
[18:21:58] [Logger Info] : Starting AMP version 2.4.6.6 (Decadeus), built 05/10/2023 11:56
[18:21:58] [Logger Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[18:21:58] [Logger Info] : Running in a Docker environment.
[18:21:58] [Logger Info] : OS: Linux / x86_64
[18:21:58] [Logger Info] : CPU: AMD Ryzen 5 3600 6-Core Processor (8C/8T)
[18:21:58] [Logger Info] : RAM: 19976MB
[18:21:58] [Logger Info] : AMP Instance ID: …
[18:21:58] [Logger Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[18:21:58] [Logger Info] : Metrics publishing is enabled at udp://localhost:12820.
[18:21:58] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[18:21:58] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[18:21:58] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[18:21:58] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[18:21:58] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[18:21:59] [Logger Info] : Licence Present: AMP Professional Edition
[18:21:59] [FileManager Notice] : No SSH keypair available for embedded server, generating new keypair…
[18:21:59] [Logger Notice] : Generated new keypair with fingerprint …
[18:21:59] [Logger Notice] : Using keypair with fingerprint …
[18:21:59] [Logger Info] : SFTP Server started on 0.0.0.0:2224
[18:21:59] [Webserver Info] : Websockets are enabled.
[18:21:59] [Logger Info] : Webserver started on …
[18:21:59] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[18:21:59] [Core Info] : Checking for AMP updates…
[18:21:59] [Logger Info] : Startup mode is StartApplication, SkipThisTime.
[18:21:59] [Core Info] : AMP is up to date.
[18:22:04] [Logger Info] : Updating Modpack cache for 86 modpacks…
[18:22:10] [Logger Activity] : Authentication attempt for user admin from 127.0.0.1
[18:22:10] [Core Activity] : Authentication success
[18:22:15] [Logger Activity] : Authentication attempt for user admin from …
[18:22:15] [Logger Activity] : Authentication failure for user admin from … - Failure
[18:22:15] [Logger Activity] : SFTP connection request from … (WinSCP_release_6.1.2)
[18:22:15] [Logger Activity] : SFTP authentication denied for admin@… : Failure
[18:22:15] [Core Activity] : Authentication success
[18:22:15] [Logger Activity] : SFTP login success for admin@…
[18:22:24] [Logger:admin Activity] : Changing setting MinecraftModule.GameSettings.Difficulty to 3
[18:22:24] [Logger Info] : Update complete.
[18:22:27] [Logger:admin Activity] : Changing setting MinecraftModule.GameSettings.SpawnProtectionRadius to 0
[18:22:27] [Logger:admin Activity] : Changing setting MinecraftModule.GameSettings.AllowFlight to True
[18:22:28] [Logger:admin Activity] : Changing setting MinecraftModule.GameSettings.EnablePVPCombat to True
[18:22:30] [Logger:admin Activity] : Changing setting MinecraftModule.GameSettings.TimeoutMins to 0
[18:22:34] [Logger:admin Activity] : Changing setting MinecraftModule.JavaSettings.JavaVersion to /usr/lib/jvm/temurin-17-jdk-amd64/bin/java
[18:22:44] [Logger:admin Activity] : Changing setting MinecraftModule.LimitsSettings.MaxViewDistance to 24
[18:22:47] [Logger:admin Activity] : Changing setting MinecraftModule.LimitsSettings.MaxPlayers to 100
[18:22:48] [Logger:admin Activity] : Changing setting MinecraftModule.LimitsSettings.LockToOfficial to True
[18:22:50] [Logger:admin Activity] : Changing setting MinecraftModule.LimitsSettings.SleepMode to False
[18:22:56] [Logger:admin Activity] : Changing setting MinecraftModule.MinecraftSettings.ServerType to 50
[18:23:02] [Logger:admin Activity] : Changing setting MinecraftModule.MinecraftSettings.SpecificForgeVersion to 47.1.3 (mc 1.20.1)
[18:23:29] [API:admin Activity] : Updating the application.
JVM info: Eclipse Adoptium - 17.0.8.1 - 17.0.8.1+1
java.net.preferIPv4Stack=true
Current Time: 19/11/2023 18:23:32
Host: … [51.79.83.165]
Host: … [13.107.213.60, 13.107.246.60]
Host: … [18.66.218.108, 18.66.218.122, 18.66.218.34, 18.66.218.18]
Found java version 17.0.8.1
Target Directory: .
Data kindly mirrored by CreeperHost at …
Considering minecraft server jar
Downloading library from https://piston-data.mojang.com/v1/objects/84194a2f286ef7c14ed7ce0090dba59902951553/server.jar
Download completed: Checksum validated.
Downloading libraries
The server installed successfully
You can delete this installer file now if you wish
[18:24:12] [API:admin Activity] : Starting the application.
[18:24:14] [API:admin Activity] : Starting the application.
[18:24:14] [Minecraft:admin Info] : Lock-To-Official is in effect, changing the server type to Official.
[18:24:14] [Logger:admin Info] : Java located at /usr/lib/jvm/temurin-17-jdk-amd64/bin/java
[18:24:14] [Logger:admin Info] : Using ‘Official’ compatibility mode.
Current Time: 19/11/2023 18:24:14
Host: … [13.107.246.60, 13.107.213.60]
Host: … [18.66.218.122, 18.66.218.108, 18.66.218.34, 18.66.218.18]
Exception in thread “main”
java.awt.HeadlessException:
No X11 DISPLAY variable was set,
but this program performed an operation which requires it.
at java.desktop/java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:166)
at java.desktop/java.awt.Window.(Window.java:553)
at java.desktop/java.awt.Frame.(Frame.java:428)
at java.desktop/java.awt.Frame.(Frame.java:393)
at java.desktop/javax.swing.SwingUtilities$SharedOwnerFrame.(SwingUtilities.java:1919)
at java.desktop/javax.swing.SwingUtilities.getSharedOwnerFrame(SwingUtilities.java:1995)
at java.desktop/javax.swing.JOptionPane.getRootFrame(JOptionPane.java:1695)
at java.desktop/javax.swing.JOptionPane.showOptionDialog(JOptionPane.java:874)
at java.desktop/javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:676)
at java.desktop/javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:647)
at net.minecraftforge.installer.SimpleInstaller.launchGui(SimpleInstaller.java:191)
at net.minecraftforge.installer.SimpleInstaller.main(SimpleInstaller.java:161)
[18:24:16] [Logger:admin Warning] : Server failed to start 1/5 times…
[18:24:16] [Logger:admin Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[18:24:25] [API:admin Activity] : Starting the application.
[18:24:25] [Logger:admin Warning] : No version metadata exists for release
[18:24:25] [Minecraft:admin Warning] : Couldn’t determine URL to fetch update from.
[19:08:44] [Logger:admin Activity] : Changing setting MinecraftModule.JavaSettings.JavaVersion to /usr/lib/jvm/temurin-18-jdk-amd64/bin/java
[19:08:47] [API:admin Activity] : Starting the application.
[19:08:47] [Logger:admin Warning] : No version metadata exists for release
[19:08:47] [Minecraft:admin Warning] : Couldn’t determine URL to fetch update from.
Thats the log without the Installation…
Yes the Jar was left to Autoselect, as no server.jar is created. Theres only the forge-installer.jar
Delete the libraries folder, then hit Download/Update under Server Settings.
See if that kicks things over
no unfortunetly that didn’t change anything either.
The installer gets downloaded again but I get the same error when trying to start
I see the X11 DISPLAY error is showing up, so it may be worth re-creating the server in a new instance. Just with the same server settings and such.
Test plain Forge first to see if everything is working smooth, then import the pack
