Startup Issue with Minecraft - unable to start server Moded
It states in the logs, but i don’t see how to fix it. It wont listen to game-port
  • Change server type to ‘‘Forge’’
  • Changed version to ‘‘1.12.2’’
  • Then I clicked on download and update.
  • I then made a ‘‘mods’’ folder in directory’’ and put the zip file inside
Make sure that you have Java 8 selected as your Java Version in the instance’s settings.
Also, zips will not work. You must have only the .jar files in the mods folder.
