| Product | AMP ‘Phobos’ v2.6.3.0 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Stopped |
Running the server locally on my machine works. Starts in minutes. AMP 15mins then dies.
- different setting, reboot, upgrade.
- Running the server locally on my machine works
- Running the server locally on my machine works. Starts in minutes. AMP 15mins then dies.
Not applying mixin 'org.embeddedt.vintagefix.mixin.version_protest.MinecraftMixin' as 'mixin.version_protest' is disabled in config
Not applying mixin ‘org.embeddedt.vintagefix.mixin.version_protest.FMLCommonHandlerMixin’ as ‘mixin.version_protest’ is disabled in config
Error loading class: net/minecraft/client/multiplayer/ChunkProviderClient (net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerException: Exception in class transformer net.minecraftforge.fml.common.asm.transformers.SideTransformer@2e807c54 from coremod FMLCorePlugin)
@Mixin target net.minecraft.client.multiplayer.ChunkProviderClient was not found mixins.vintagefix.json:chunk_access.ChunkProviderClientMixin from mod unknown-owner
@Mixin target net.minecraft.client.multiplayer.ChunkProviderClient was not found mixins.vintagefix.json:bugfix.entity_disappearing.AccessorChunkProviderClient from mod unknown-owner
Error loading class: net/minecraft/client/renderer/RenderGlobal (net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerException: Exception in class transformer net.minecraftforge.fml.common.asm.transformers.SideTransformer@2e807c54 from coremod FMLCorePlugin)
@Mixin target net.minecraft.client.renderer.RenderGlobal was not found mixins.vintagefix.json:bugfix.entity_disappearing.MixinRenderGlobal from mod unknown-owner
Error loading class: net/minecraft/server/integrated/IntegratedServer (net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerException: Exception in class transformer net.minecraftforge.fml.common.asm.transformers.SideTransformer@2e807c54 from coremod FMLCorePlugin)
@Mixin target net.minecraft.server.integrated.IntegratedServer was not found mixins.vintagefix.json:bugfix.exit_freeze.IntegratedServerMixin from mod unknown-owner
Error loading class: net/minecraft/client/renderer/texture/TextureMap (net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerException: Exception in class transformer net.minecraftforge.fml.common.asm.transformers.SideTransformer@2e807c54 from coremod FMLCorePlugin)
@Mixin target net.minecraft.client.renderer.texture.TextureMap was not found mixins.vintagefix.json:dynamic_resources.MixinTextureMap from mod unknown-owner
Error loading class: net/minecraft/client/renderer/RenderItem (net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerException: Exception in class transformer net.minecraftforge.fml.common.asm.transformers.SideTransformer@2e807c54 from coremod FMLCorePlugin)
@Mixin target net.minecraft.client.renderer.RenderItem was not found mixins.vintagefix.json:dynamic_resources.MixinRenderItem from mod unknown-owner
