Field | Value |
Product | AMP ‘Phobos’ v2.6.2.4 (Mainline) |
Virtualization | Docker |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | Yes |
Current State | Failed |
When I try to start the server, the message ‘The Minecraft server repeatedly failed to start, this is not a fault with AMP - you should check your Minecraft server’s log files to find out why it is unable to start’ appears.
- if a start
- I’ve already tried adjusting the properties.
- I’ve already tried adjusting the settings.
