Startup Issue with Minecraft - Trying to install a custom modpack
It keeps crashing when I try to start the server. I checked the logs and cant figure out what is causing the issue it seems like everything is fine till the end when it goes to actually start it.
  • Installed mods
  • change version
  • update the server
  • start the server
You’ll want to share the error from the logs
[05:38:52.377] [main/WARN]: Error loading class: net/caffeinemc/mods/sodium/client/render/chunk/compile/pipeline/DefaultFluidRenderer (java.lang.ClassNotFoundException: net.caffeinemc.mods.sodium.client.render.chunk.compile.pipeline.DefaultFluidRenderer)
[05:38:52.591] [main/ERROR]: Attempted to load class net/minecraft/client/Minecraft for invalid dist DEDICATED_SERVER
[05:38:52.594] [main/WARN]: Error loading class: net/minecraft/client/Minecraft (java.lang.RuntimeException: Attempted to load class net/minecraft/client/Minecraft for invalid dist DEDICATED_SERVER)
[05:38:52.594] [main/WARN]: @Mixin target net.minecraft.client.Minecraft was not found omega-config.mixins.json:ClientMixin from mod omegaconfig
00:38:53
[05:38:53.300] [main/INFO]: Skipping issue #8221 from mod mekanism as it is client side only!
[05:38:53.300] [main/INFO]: Skipping issue [untracked] from mod mahoutsukai as it is client side only!
[05:38:53.300] [main/INFO]: Skipping issue [untracked] from mod justenoughprofessions as it is client side only!
[05:38:53.302] [main/INFO]: Skipping issue [untracked] from mod justdirethings as it is client side only!
[05:38:53.302] [main/INFO]: Skipping issue [untracked] from mod journeymap as it is client side only!
[05:38:53.302] [main/INFO]: Skipping issue [untracked] from mod jei as it is client side only!
[05:38:53.302] [main/INFO]: Skipping issue [untracked] from mod jade as it is client side only!
[05:38:53.305] [main/INFO]: Skipping issue #556 from mod irons_spellbooks as it is client side only!
[05:38:53.305] [main/INFO]: Skipping issue [untracked] from mod iceberg as it is client side only!
[05:38:53.306] [main/INFO]: Skipping issue [untracked] from mod iceberg as it is client side only!
[05:38:53.306] [main/INFO]: Skipping issue [untracked] from mod geckolib as it is client side only!
[05:38:53.306] [main/INFO]: Skipping issue [untracked] from mod ftblibrary as it is client side only!
[05:38:53.307] [main/INFO]: Skipping issue [untracked] from mod findme as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod entity_texture_features as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod entity_model_features as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod entityculling as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod emi_loot as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod emi as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod buildinggadgets2 as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod badpackets as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod athena as it is client side only!
[05:38:53.308] [main/INFO]: Skipping issue [untracked] from mod ars_nouveau as it is client side only!
[05:38:53.308] [main/INFO]: Class dev.uncandango.alltheleaks.fix.common.mods.kubejs.FixRecipeSchemas will be loaded as it matches versions: 2101.7.1-build.181 in [2101.7.1-build.181,2101.7.1-build.187]
[05:38:53.311] [main/INFO]: Mixins added to allowed list: [main.RecipeComponentBuilderMixin, main.RecipeComponentBuilderMixin$ValueMixin, main.RecipeComponentBuilderMixin$MapCodecMixin, main.RegistryComponentMixin]
[05:38:53.312] [main/INFO]: Class dev.uncandango.alltheleaks.fix.common.mods.kubejs.FixCachedTagLookup will be loaded as it matches versions: 2101.7.1-build.181 in [2101.7.1-build.181,2101.7.1-build.187]
[05:38:53.312] [main/INFO]: Mixins added to allowed list: [main.CachedTagLookupMixin]
[05:38:53.312] [main/INFO]: Skipping issue #1932 from mod neoforge as it is client side only!
[05:38:53.316] [main/INFO]: Skipping feature Ingredient Deduplication from mod minecraft as it’s feature flag is not activated!
[05:38:53.316] [main/INFO]: Skipping feature Scoreboard Debug from mod minecraft as it’s feature flag is not activated!
[05:38:53.316] [main/INFO]: Skipping feature Entity Section CME Debug from mod minecraft as it’s feature flag is not activated!
[05:38:53.316] [main/INFO]: Skipping feature Debug Native Images from mod minecraft as it’s feature flag is not activated!
[05:38:53.317] [main/INFO]: Skipping feature Debug ItemStack modifications from mod minecraft as it’s feature flag is not activated!
[05:38:53.538] [main/INFO]: Replaced 1 calls to Enchantment#getMaxLevel() in net/minecraft/world/item/enchantment/EnchantmentHelper
[05:38:53.586] [main/WARN]: Error loading class: vazkii/quark/addons/oddities/inventory/BackpackMenu (java.lang.ClassNotFoundException: vazkii.quark.addons.oddities.inventory.BackpackMenu)
[05:38:53.628] [main/ERROR]: Attempted to load class net/minecraft/client/resources/model/ModelBakery$ModelBakerImpl for invalid dist DEDICATED_SERVER
[05:38:53.630] [main/WARN]: Error loading class: net/minecraft/client/resources/model/ModelBakery$ModelBakerImpl (java.lang.RuntimeException: Attempted to load class net/minecraft/client/resources/model/ModelBakery$ModelBakerImpl for invalid dist DEDICATED_SERVER)
[05:38:53.630] [main/WARN]: @Mixin target net.minecraft.client.resources.model.ModelBakery$ModelBakerImpl was not found ctm.mixins.json:TextureScrapingMixin from mod ctm
[05:38:53.795] [main/INFO]: Replaced 2 calls to Enchantment#getMaxLevel() in net/minecraft/world/inventory/AnvilMenu
[05:38:53.801] [main/WARN]: Error loading class: org/violetmoon/quark/content/tweaks/module/GoldToolsHaveFortuneModule (java.lang.ClassNotFoundException: org.violetmoon.quark.content.tweaks.module.GoldToolsHaveFortuneModule)
[05:38:53.815] [main/WARN]: Error loading class: org/violetmoon/quark/content/tweaks/module/GoldToolsHaveFortuneModule (java.lang.ClassNotFoundException: org.violetmoon.quark.content.tweaks.module.GoldToolsHaveFortuneModule)
00:38:54
[05:38:54.033] [main/ERROR]: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
[05:38:54.034] [main/WARN]: Error loading class: net/minecraft/client/gui/screens/Screen (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER)
[05:38:54.035] [main/WARN]: @Mixin target net.minecraft.client.gui.screens.Screen was not found relics.mixins.json:ScreenMixin from mod relics
[05:38:54.037] [main/ERROR]: Attempted to load class net/minecraft/client/KeyMapping for invalid dist DEDICATED_SERVER
[05:38:54.039] [main/WARN]: Error loading class: net/minecraft/client/KeyMapping (java.lang.RuntimeException: Attempted to load class net/minecraft/client/KeyMapping for invalid dist DEDICATED_SERVER)
[05:38:54.039] [main/WARN]: @Mixin target net.minecraft.client.KeyMapping was not found nuggets.mixins.json:KeyMappingAccessor from mod nuggets
[05:38:54.043] [main/ERROR]: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
[05:38:54.044] [main/WARN]: Error loading class: net/minecraft/client/gui/screens/Screen (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER)
[05:38:54.044] [main/WARN]: @Mixin target net.minecraft.client.gui.screens.Screen was not found nuggets.mixins.json:ScreenAccessor from mod nuggets
[05:38:54.075] [main/WARN]: Error loading class: net/minecraft/client/renderer/entity/PhantomRenderer (java.lang.ClassNotFoundException: net.minecraft.client.renderer.entity.PhantomRenderer)
[05:38:54.076] [main/WARN]: @Mixin target net.minecraft.client.renderer.entity.PhantomRenderer was not found deeperdarker.mixins.json:PhantomRendererMixin from mod deeperdarker
[05:38:54.238] [main/ERROR]: Attempted to load class net/minecraft/client/gui/screens/inventory/AbstractContainerScreen for invalid dist DEDICATED_SERVER
[05:38:54.240] [main/WARN]: Error loading class: net/minecraft/client/gui/screens/inventory/AbstractContainerScreen (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/inventory/AbstractContainerScreen for invalid dist DEDICATED_SERVER)
[05:38:54.241] [main/WARN]: @Mixin target net.minecraft.client.gui.screens.inventory.AbstractContainerScreen was not found chisel.mixins.json:HandledScreenAccessor from mod chisel
[05:38:54.476] [main/WARN]: Error loading class: com/mojang/blaze3d/platform/InputConstants$Key (java.lang.ClassNotFoundException: com.mojang.blaze3d.platform.InputConstants$Key)
WARN StatusConsoleListener Advanced terminal features are not available in this environment
main/INFO00:38:54
Initializing MixinExtras via nolijium.mixinextras.service.MixinExtrasServiceImpl(version=0.4.1).
main/WARN00:38:54
Static binding violation: PRIVATE @Overwrite method decoratedId in modernfix-neoforge.mixins.json:perf.tag_id_caching.TagOrElementLocationMixin from mod modernfix cannot reduce visibiliy of PUBLIC target method, visibility will be upgraded.
main/INFO00:38:55
ModernFix reached bootstrap stage (21.29 s after launch)
Console00:38:55
The Euphoria Patcher Mod should not be loaded on a server! Disabling…
main/INFO00:38:55
Replaced 2 calls to Enchantment#getMaxLevel() in net/minecraft/world/item/CreativeModeTabs
main/WARN00:38:56
Method overwrite conflict for getTeamColor in ars_nouveau.mixins.json:perks.PerkLivingEntity from mod ars_nouveau, previously written by dev.shadowsoffire.apotheosis.mixin.LivingEntityMixin. Skipping method.
00:38:57
Static binding violation: PRIVATE @Overwrite method getTemperature in modernfix-common.mixins.json:perf.remove_biome_temperature_cache.BiomeMixin from mod modernfix cannot reduce visibiliy of PUBLIC target method, visibility will be upgraded.
main/INFO00:38:57
main/WARN00:38:58
Method overwrite conflict for setChanged in amendments-common.mixins.json:LecternBlockEntityMixin from mod amendments, previously written by io.redspace.ironsspellbooks.mixin.LecternBlockEntityMixin. Skipping method.
Method overwrite conflict for getUpdateTag in amendments-common.mixins.json:LecternBlockEntityUpdateMixin from mod amendments, previously written by io.redspace.ironsspellbooks.mixin.LecternBlockEntityMixin. Skipping method.
Method overwrite conflict for getUpdatePacket in amendments-common.mixins.json:LecternBlockEntityUpdateMixin from mod amendments, previously written by io.redspace.ironsspellbooks.mixin.LecternBlockEntityMixin. Skipping method.
main/INFO00:38:58
main/WARN00:38:59
Method overwrite conflict for scheduleRandomTick in ohthetreesyoullgrow.mixins.json:chunk.MixinChunkAccess from mod ohthetreesyoullgrow, previously written by corgitaco.corgilib.mixin.chunk.MixinChunkAccess. Skipping method.
Method overwrite conflict for getScheduledRandomTicks in ohthetreesyoullgrow.mixins.json:chunk.MixinChunkAccess from mod ohthetreesyoullgrow, previously written by corgitaco.corgilib.mixin.chunk.MixinChunkAccess. Skipping method.
main/INFO00:39:00
Patching FishingHook#catchingFish
00:39:01
Replaced 1 calls to Enchantment#getMaxLevel() in net/minecraft/world/level/storage/loot/functions/EnchantRandomlyFunction
00:39:02
Replaced 1 calls to Enchantment#getMaxLevel() in net/minecraft/world/item/enchantment/providers/SingleEnchantment
Vanilla bootstrap took 7604 milliseconds
modloading-worker-0/INFO00:39:03
NeoForge mod loading, version 21.1.119, for MC 1.21.1
00:39:05
Scanning classes for industrialforegoing
Found FeaturePluginInstance for class FTBChunksPlugin for plugin ftbchunks
Found FeaturePluginInstance for class PatchouliPlugin for plugin patchouli
Found FeaturePluginInstance for class CuriosPlugin for plugin curios
Constructed class FTBChunksPlugin for plugin ftbchunks for mod industrialforegoing
Constructed class PatchouliPlugin for plugin patchouli for mod industrialforegoing
Constructed class CuriosPlugin for plugin curios for mod industrialforegoing
Executing phase CONSTRUCTION for plugin class FTBChunksPlugin
Executing phase CONSTRUCTION for plugin class PatchouliPlugin
Executing phase CONSTRUCTION for plugin class CuriosPlugin
Executing phase PRE_INIT for plugin class FTBChunksPlugin
Executing phase PRE_INIT for plugin class PatchouliPlugin
Executing phase PRE_INIT for plugin class CuriosPlugin
Executing phase INIT for plugin class FTBChunksPlugin
Executing phase INIT for plugin class PatchouliPlugin
Executing phase INIT for plugin class CuriosPlugin
Executing phase POST_INIT for plugin class FTBChunksPlugin
Executing phase POST_INIT for plugin class PatchouliPlugin
Executing phase POST_INIT for plugin class CuriosPlugin
00:39:06
Better Compatibility Checker starting
Registering mod: allthecompressed
Registering overlays for loaded mods: [allthecompressed, allthemodium, alltheores, allthetweaks, ae2, appflux, enderio, extendedae, megacells, minecraft, pneumaticcraft, powah, productivebees, supplementaries, xycraft_world]
Skipping overlays for absent mods: [botania]
00:39:07
Loaded NeoForgeRegistrationFactory for service Factory
Scanning classes for sushigocrafting
Constructed class PatchouliPlugin for plugin patchouli for mod sushigocrafting
Console00:39:07
modloading-worker-0/INFO00:39:07
Loading Glassential Renewed - NeoForge
Console00:39:08
at TRANSFORMER/moreoverlays@1.23.2-neoforge/at.ridgo8.moreoverlays.KeyBindings.(KeyBindings.java:17) ~[?:?] {re:classloading}
at java.base/java.lang.Class.forName0(Native Method) ~[?:?] {re:mixin}
at java.base/java.lang.Class.forName(Class.java:534) ~[?:?] {re:mixin}
at java.base/java.lang.Class.forName(Class.java:513) ~[?:?] {re:mixin}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.javafmlmod.AutomaticEventSubscriber.lambda$inject$4(AutomaticEventSubscriber.java:60) ~[loader-4.0.35.jar%2360!/:4.0] {}
at java.base/java.util.ArrayList.forEach(ArrayList.java:1596) ~[?:?] {re:mixin}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.javafmlmod.AutomaticEventSubscriber.inject(AutomaticEventSubscriber.java:44) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.javafmlmod.FMLModContainer.constructMod(FMLModContainer.java:126) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.ModLoader.lambda$constructMods$3(ModLoader.java:153) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.ModLoader.lambda$dispatchParallelTask$7(ModLoader.java:231) ~[loader-4.0.35.jar%2360!/:4.0] {}
at java.base/java.util.concurrent.CompletableFuture.uniHandle(CompletableFuture.java:934) [?:?] {re:mixin}
at java.base/java.util.concurrent.CompletableFuture$UniHandle.tryFire(CompletableFuture.java:911) [?:?] {}
at java.base/java.util.concurrent.CompletableFuture$Completion.exec(CompletableFuture.java:483) [?:?] {}
at java.base/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:387) [?:?] {}
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1312) [?:?] {}
at java.base/java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1843) [?:?] {re:mixin,re:computing_frames}
at java.base/java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1808) [?:?] {re:mixin,re:computing_frames}
at java.base/java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:188) [?:?] {re:mixin}
Caused by: java.lang.RuntimeException: Attempted to load class net/minecraft/client/KeyMapping for invalid dist DEDICATED_SERVER
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.common.asm.RuntimeDistCleaner.processClassWithFlags(RuntimeDistCleaner.java:60) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.LaunchPluginHandler.offerClassNodeToPlugins(LaunchPluginHandler.java:94) ~[modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.ClassTransformer.transform(ClassTransformer.java:120) ~[modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.TransformingClassLoader.maybeTransformClassBytes(TransformingClassLoader.java:57) ~[modlauncher-11.0.4.jar%2362!/:?] {}
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.readerToClass(ModuleClassLoader.java:190) ~[securejarhandler-3.0.8.jar:?] {}
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.lambda$findClass$20(ModuleClassLoader.java:298) ~[securejarhandler-3.0.8.jar:?] {}
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadFromModule(ModuleClassLoader.java:311) ~[securejarhandler-3.0.8.jar:?] {}
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.findClass(ModuleClassLoader.java:298) ~[securejarhandler-3.0.8.jar:?] {}
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadClass(ModuleClassLoader.java:214) ~[securejarhandler-3.0.8.jar:?] {}
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:526) ~[?:?] {}
… 18 more
modloading-worker-0/INFO00:39:08
Loaded config for: cupboard.json
Console00:39:08
No matching files were found.
Registered class observable.net.C2SPacket$InitTPSProfile
Registered class observable.net.C2SPacket$RequestAvailability
Registered class observable.net.S2CPacket$ProfilingStarted
Registered class observable.net.S2CPacket$ProfilingCompleted
Registered class observable.net.S2CPacket$ProfilerInactive
Registered class observable.net.S2CPacket$ProfilingResult
Registered class observable.net.S2CPacket$Availability
Redstone Pen GIT id #f8a37d5.
00:39:09
Registered plugin: com.blakebr0.mysticalagriculture.lib.ModCorePlugin
Registered plugin: com.blakebr0.mysticalcustomization.lib.ModCorePlugin
Registered plugin: com.blakebr0.mysticalagradditions.lib.ModCorePlugin
Loaded 3 plugins
00:39:10
Registering mod: pylons
Scanning classes for functionalstorage
modloading-worker-0/WARN00:39:10
[JUST ZOOM]: Disabling ‘Just Zoom’ since it’s a client-side mod and current environment is server!
modloading-worker-0/INFO00:39:10
Initialize quarryplus with com.kotori316.scala_lib.ScalaModContainer
loading
loaded for NeoForge, PlatformAccessNeoForge
Initialize finished quarryplus
00:39:11
Deserializing ModMobsConfig from ‘config/variantsandventures/mod_mobs.json’
Deserializing VanillaMobsConfig from ‘config/variantsandventures/vanilla_mobs.json’
Successfully loaded Modern Dynamics!
Registering mod: novillagerdm
Initializing Torchmaster for platform NeoForge
Debug Logging Enabled: false
modloading-worker-0/WARN00:39:11
Static binding violation: PRIVATE @Overwrite method elementOrTag in modernfix-neoforge.mixins.json:perf.tag_id_caching.TagEntryMixin from mod modernfix cannot reduce visibiliy of PUBLIC target method, visibility will be upgraded.
modloading-worker-0/INFO00:39:11
Loaded V1.5.5+1.21.1!
00:39:12
Starting Bean Context
Bean Context loaded in 130 ms
Console00:39:14
[Mouse Tweaks] Disabled because not running on the client.
modloading-worker-0/INFO00:39:15
Kotlin For Forge Enabled!
Registering Oh The Biomes We’ve Gone items
Registering Oh The Biomes We’ve Gone Blocks
Registering Oh The Biomes We’ve Gone Wood
Registering Oh The Biomes We’ve Gone Block Entities
Registering Oh The Biomes We’ve Gone Entities
Registering Oh The Biomes We’ve Gone Creative Tabs
Registering Oh The Biomes We’ve Gone Sounds
Registering Oh The Biomes We’ve Gone Block Predicate
Registering Oh The Biomes We’ve Gone State Providers
Registering Oh The Biomes We’ve Gone Tree Decorators
Registering Oh The Biomes We’ve Gone Custom Features
Registering Oh The Biomes We’ve Gone Structure Pieces
Registering Oh The Biomes We’ve Gone Custom Structure Types
Registering Oh The Biomes We’ve Gone Configured Features
Creating and Registering Overworld Vegetation Configured Features
Registering Oh The Biomes We’ve Gone Tree Configured Features
Creating and Registering Vanilla Configured Features
Registering Oh The Biomes You’ll Go Overworld Configured Features
Registering Oh The Biomes We’ve Gone Placed Features
Creating and Registering Overworld Tree Placed Features
Creating and Registering Overworld Vegetation Placed Features
Creating and Registering Vanilla Placed Features
Registering Oh The Biomes We’ve Gone Custom Surface Rules
Registering Oh The Biomes We’ve Gone Template Pools
Registering Oh The Biome’s We’ve Gone Village Template Pools
Registering Oh The Biomes We’ve Gone Poi Types
Registering Oh The Biomes We’ve Gone Villager Professions
Registering Oh The Biomes We’ve Gone Custom Structure Processors
00:39:17
FTB Ranks detected, listening for ranks events
Scanning classes for mifa
Loading T&T
Initializing JamLib on NeoForge
00:39:18
Loading vanilla registries…
Looking for KubeJS plugins…
Found plugin source kubejs
modloading-worker-0/WARN00:39:18
Plugin dev.latvian.mods.kubejs.client.BuiltinKubeJSClientPlugin does not load on server side, skipping
Plugin dev.latvian.mods.kubejs.integration.gamestages.GameStagesIntegration does not have required mod ‘gamestages’ loaded, skipping
modloading-worker-0/INFO00:39:18
Found plugin source theurgy_kubejs
Found plugin source modular_machinery_reborn
Found plugin source modular_machinery_reborn_mekanism
Found plugin source ftbxmodcompat
Found plugin source occultism_kubejs
Found plugin source extendedae
Found plugin source modern_industrialization
Done in 57.00 ms
[FTB Quests]: Enabled KubeJS integration
[FTB Chunks]: Enabled KubeJS integration
Added bindings for script type STARTUP from mod ‘almostunified’: [AlmostUnified]
Loaded script startup_scripts:Potionsmaster/potionsmaster.js in 0.144 s
startup_scripts:Shrink/polylib_fix.js#1: Loaded Java class ‘net.creeperhost.polylib.init.DataComps’
Loaded script startup_scripts:Shrink/polylib_fix.js in 0.002 s
startup_scripts:CustomAdditions.js#4: Loaded Java class ‘net.minecraft.core.registries.BuiltInRegistries’
Loaded script startup_scripts:CustomAdditions.js in 0.022 s
Loaded script startup_scripts:Xycraft/Compatibility.js in 0.001 s
00:39:19
startup_scripts:Mekanism/Compatibility.js#18: Loaded Java class ‘mekanism.api.chemical.Chemical’
startup_scripts:Mekanism/Compatibility.js#19: Loaded Java class ‘mekanism.api.chemical.ChemicalBuilder’
Loaded script startup_scripts:Mekanism/Compatibility.js in 0.018 s
startup_scripts:hyperbox/hyperbox.js#1: Loaded Java class ‘net.neoforged.neoforge.event.entity.player.PlayerEvent$PlayerChangedDimensionEvent’
Loaded script startup_scripts:hyperbox/hyperbox.js in 0.015 s
Loaded script startup_scripts:Applied Energistics/Universal_Press.js in 0.0 s
Loaded script startup_scripts:ExtendedAE/InfinityCells.js in 0.002 s
Loaded script startup_scripts:Farmer’s Delight/Compatibility.js in 0.0 s
Loaded script startup_scripts:Modern-Industrialization/atm_stuff.js in 0.001 s
Loaded script startup_scripts:Theurgy/SulfurAdditions.js in 0.001 s
Loaded 11/11 KubeJS startup scripts in 0.844 s with 0 errors and 0 warnings
Here we go! Launching Dungeon Crawl 2.3.15…
Scanning classes for titanium
Initializing Regions Unexplored from Forge Mod Initializer entrypoint.
Console00:39:20
TEST
TEST2
modloading-worker-0/INFO00:39:20
Starting MI hook entrypoint loader
Registered entrypoint for mod tesseract_api: net.swedz.tesseract.neoforge.compat.mi.hook.builtin.TesseractMIHookListener
Registered entrypoint for mod extended_industrialization: net.swedz.extended_industrialization.compat.mi.EIMIHookListener
Registered entrypoint for mod extended_industrialization: net.swedz.extended_industrialization.compat.mi.EIMIHookRegistry
Done MI hook entrypoint loader
Console00:39:21
YungsBetterDesertTemples-1.21.1-NeoForge-4.1.3.jar|YUNG’s Better Desert Temples |betterdeserttemples |1.21.1-NeoForge-4.1.|Manifest: NOSIGNATURE
YungsBetterDungeons-1.21.1-NeoForge-5.1.4.jar |YUNG’s Better Dungeons |betterdungeons |1.21.1-NeoForge-5.1.|Manifest: NOSIGNATURE
YungsBetterEndIsland-1.21.1-NeoForge-3.1.1.jar |YUNG’s Better End Island |betterendisland |1.21.1-NeoForge-3.1.|Manifest: NOSIGNATURE
YungsBetterJungleTemples-1.21.1-NeoForge-3.1.2.jar|YUNG’s Better Jungle Temples |betterjungletemples |1.21.1-NeoForge-3.1.|Manifest: NOSIGNATURE
YungsBetterMineshafts-1.21.1-NeoForge-5.1.1.jar |YUNG’s Better Mineshafts |bettermineshafts |1.21.1-NeoForge-5.1.|Manifest: NOSIGNATURE
YungsBetterNetherFortresses-1.21.1-NeoForge-3.1.3.|YUNG’s Better Nether Fortresse|betterfortresses |1.21.1-NeoForge-3.1.|Manifest: NOSIGNATURE
YungsBetterOceanMonuments-1.21.1-NeoForge-4.1.2.ja|YUNG’s Better Ocean Monuments |betteroceanmonuments |1.21.1-NeoForge-4.1.|Manifest: NOSIGNATURE
YungsBetterStrongholds-1.21.1-NeoForge-5.1.2.jar |YUNG’s Better Strongholds |betterstrongholds |1.21.1-NeoForge-5.1.|Manifest: NOSIGNATURE
YungsBetterWitchHuts-1.21.1-NeoForge-4.1.1.jar |YUNG’s Better Witch Huts |betterwitchhuts |1.21.1-NeoForge-4.1.|Manifest: NOSIGNATURE
YungsExtras-1.21.1-NeoForge-5.1.1.jar |YUNG’s Extras |yungsextras |1.21.1-NeoForge-5.1.|Manifest: NOSIGNATURE
ZeroCore2-1.21.1-2.4.16.jar |Zero CORE 2 |zerocore |1.21.1-2.4.16 |Manifest: NOSIGNATURE
Crash Report UUID: e136d2fe-b996-41a8-8d0a-588d194aaa82
FML: 4.0.35
NeoForge: 21.1.119
main/ERROR00:39:21
Failed to start the minecraft server
Console00:39:21
net.neoforged.fml.ModLoadingException: Loading errors encountered:
- More Overlays Updated (moreoverlays) has failed to load correctly
java.lang.BootstrapMethodError: java.lang.RuntimeException: Attempted to load class net/minecraft/client/KeyMapping for invalid dist DEDICATED_SERVER
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.ModLoader.waitForFuture(ModLoader.java:281) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.ModLoader.dispatchParallelTask(ModLoader.java:244) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.ModLoader.constructMods(ModLoader.java:152) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.ModLoader.gatherAndInitializeMods(ModLoader.java:142) ~[loader-4.0.35.jar%2360!/:4.0] {}
at TRANSFORMER/neoforge@21.1.119/net.neoforged.neoforge.internal.CommonModLoader.begin(CommonModLoader.java:49) ~[neoforge-21.1.119-universal.jar%23535!/:?] {re:classloading}
at TRANSFORMER/neoforge@21.1.119/net.neoforged.neoforge.server.loading.ServerModLoader.load(ServerModLoader.java:34) ~[neoforge-21.1.119-universal.jar%23535!/:?] {re:classloading}
at TRANSFORMER/minecraft@1.21.1/net.minecraft.server.Main.main(Main.java:124) ~[server-1.21.1-20240808.144430-srg.jar%23534!/:?] {re:classloading}
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?] {}
at java.base/java.lang.reflect.Method.invoke(Method.java:580) ~[?:?] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.loading.targets.CommonLaunchHandler.runTarget(CommonLaunchHandler.java:136) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.loading.targets.CommonLaunchHandler.serverService(CommonLaunchHandler.java:128) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.loading.targets.CommonServerLaunchHandler.runService(CommonServerLaunchHandler.java:32) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/fml_loader@4.0.35/net.neoforged.fml.loading.targets.CommonLaunchHandler.lambda$launchService$4(CommonLaunchHandler.java:118) ~[loader-4.0.35.jar%2360!/:4.0] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.LaunchServiceHandlerDecorator.launch(LaunchServiceHandlerDecorator.java:30) [modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:53) [modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:71) [modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.Launcher.run(Launcher.java:103) [modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.Launcher.main(Launcher.java:74) [modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:26) [modlauncher-11.0.4.jar%2362!/:?] {}
at MC-BOOTSTRAP/cpw.mods.modlauncher@11.0.4/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:23) [modlauncher-11.0.4.jar%2362!/:?] {}
at cpw.mods.bootstraplauncher@2.0.2/cpw.mods.bootstraplauncher.BootstrapLauncher.run(BootstrapLauncher.java:210) [bootstraplauncher-2.0.2.jar:?] {}
It says More Overlays Updated (moreoverlays) has failed to load correctly
Remove that from the server, as it’s probably a client-only mod that’s incompatible.
