| Operating System | Linux - Debian GNU/Linux 11 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | QEMU_KVM |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Failed |
Tried to add a cursedforge modpack “Dungeons Dragons and Spaceshuttles”
Following a guide, from HostingerAcademy
Created the Mods folder
Added the forge 1.12.2 Zip into the mods folder
Added the Server zip for the modpack into the mods folder.
Unable to start
Given the error:
The Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.
- Created the Mods folder
- Added the forge 1.12.2 Zip into the mods folder
- Added the Server zip for the modpack into the mods folder.
- Configured Instance to Forge 1.12.2
Console:
Installer
16:49:58
Considering library org.scala-lang:scala-library:2.11.1
File exists: Checksum validated.
Considering library org.scala-lang:scala-parser-combinators_2.11:1.0.1
Considering library org.scala-lang:scala-reflect:2.11.1
Considering library org.scala-lang:scala-swing_2.11:1.0.1
Considering library org.scala-lang:scala-xml_2.11:1.0.2
Considering library lzma:lzma:0.0.1
Considering library java3d:vecmath:1.5.2
Considering library net.sf.trove4j:trove4j:3.0.3
Considering library org.apache.maven:maven-artifact:3.5.3
Considering library net.sf.jopt-simple:jopt-simple:5.0.3
Considering library org.apache.logging.log4j:log4j-api:2.15.0
Considering library org.apache.logging.log4j:log4j-core:2.15.0
Building Processors
The server installed successfully
You can delete this installer file now if you wish
Console
16:50:07
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.run(ServerLaunchWrapper.java:70)
at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.main(ServerLaunchWrapper.java:34)
Caused by: java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader ‘bootstrap’)
at net.minecraft.launchwrapper.Launch.(Launch.java:34)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
… 6 more
