Startup Issue with Minecraft - TPS low, although resource usage is minimal
Current State Starting
The server was running fine before, 20/20 TPS all the time, now it’s running on max 6 TPS wihout any possibility to play. What is the issue here? The resources usage is low and running on a powerful server.
Errors cause the server to restart, although no changes were made. Server is running on 16GB of RAM and the server has 32GB, CPU utilization is at max 2%
  • Checked Resource Usage, it is low, checked logs, many errors, but not regarding the server itself or the modpack as it was running well before without any changes
  • Checked resource usage, it’s minimal
  • Checked logs
  • Reduced the render and simulation distance to 8
Minecraft is mostly singlethreaded, so low TPS with low CPU usage is to be expected.
You’ll want to look at single-core calculations for a better read on the situation.
Use the Spark plugin/mod to diagnose what’s using CPU time on the server.
