Startup Issue with Minecraft - The Server doesnt start after following the guide
i wanted to create another instance and keep my first one and let it keep running while another server with other stuff runns at the same time. I followed the support video like it did with the first instance and i runns with no problem at the moment. The second instance stops after 5 sec and tells me that thers no fault from amp. and that is in the console
Exception in thread “main” java.lang.IllegalAccessError: class cpw.mods.modlauncher.SecureJarHandler (in unnamed module @0x5b8bc155) cannot access class sun.security.util.ManifestEntryVerifier (in module java.base) because module java.base does not export sun.security.util to unnamed module @0x5b8bc155
  • created the instance
  • stopped server added forge
  • added mod folder with mods and wanted to start it
You need to use the right Java runtime for the version of Forge you’re running:
Thank you for the quick help :smile:
