Startup Issue with Minecraft - startup problem minecraft java 1.20.1
i tryed starting the instance and then it says: “Unable to start server.The Minecraft server repeatedly failed to start, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.” I searched everything in the internet and nothing worked.
  • i pressed on start instance
  • error message poped up
  • i look at the logs nothing is wrong
