So when the start up fails this appears: The Minecraft server repeatedly failed to start, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.
And when I go to the console register this appears:
java.nio.file.AccessDeniedException: ./30kEarth/session.lock
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:90) ~[?:?] {}
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:106) ~[?:?] {}
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111) ~[?:?] {}
Use the web file manager to remove the ./30kEarth/session.lock file, then try again.
The error usually means that the world was still in use when it was exported/uploaded, which can sometimes lead to data loss.
If you have the world, I would suggest making sure that your singleplayer world is fully exited before uploading the world folder.
I suspended the uploading process for various hours and when I came back, there was an error that I think was related to some data transfer error but I could resume it normally so it might be that, thank you.
