Startup Issue with Minecraft - Something with server generaotrs
This is all I did and Im not suire whats wrong and would like to figure out a way to fix it
  • I tried reloading the server with a new seed word name so on
  • It wouldnt boot and crashed i tried configuring server properties and mutsve caused a mess
  • I deleted server properties because I thought i would reload it
You need to import your changes if you edit the server.properties file directly.
Double-check that you have the World Seed and Level Name settings configured as you need.
If you want to change the seed and have already generated a world, you can delete the world folder if you don’t need it (the seed is baked into the world’s level.dat).
