Field | Value |
Product | AMP ‘Callisto’ v2.5.1.2 (Mainline) |
Virtualization | Docker |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | Yes |
Current State | Failed |
I tried to start the Server And it won’t Start, i already tried everything but it won’t Work this error always Pops Up!
“The Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.” and i checked The Console too and this Error always comes up " Exception in thread “main” java.lang.IllegalAccessError: class cpw.mods.modlauncher.SecureJarHandler (in unnamed module @0x6ce2b319) cannot access class sun.security.util.ManifestEntryVerifier (in module java.base) because module java.base does not export sun.security.util to unnamed module @0x6ce2b319at cpw.mods.modlauncher.SecureJarHandler.lambda$static$1(SecureJarHandler.java:45)at cpw.mods.modlauncher.api.LamdbaExceptionUtils.uncheck(LamdbaExceptionUtils.java:95)"
- Read the error
- Looked for the Tips the error gave me
- searched the error online
- Tried deleting some mods
- Checked if everything is using the same Version
