Startup Issue with Minecraft - server wont start properly
when I turn on the server, it turns off immediately.
‘The Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.’ but there is nothing written in the logs except server start line:
[30Dec2023 20:06:03.296] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher running: args [–gameDir, ., --launchTarget, fmlserver, --fml.forgeVersion, 36.2.34, --fml.mcpVersion, 20210115.111550, --fml.mcVersion, 1.16.5, --fml.forgeGroup, net.minecraftforge, nogui]
[30Dec2023 20:06:03.301] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher 8.1.3+8.1.3+main-8.1.x.c94d18ec starting: java version 18.0.2.1 by Eclipse Adoptium
*update forge
  • restart instance
  • start server
Make sure the server type is set to forge and that the correct version is selected
Yeah, it is. Idk why it won’t sart
What are the arguments shown in the support tab?
Ticket sent me here. In poping up window i got this: ’ Unable to start server.
I checked the console and there was this:
Exception in thread “main” java.lang.IllegalAccessError: class cpw.mods.modlauncher.SecureJarHandler (in unnamed module @0x4a684241) cannot access class sun.security.util.ManifestEntryVerifier (in module java.base) because module java.base does not export sun.security.util to unnamed module @0x4a684241
at cpw.mods.modlauncher.SecureJarHandler.lambda$static$1(SecureJarHandler.java:45)
at cpw.mods.modlauncher.api.LamdbaExceptionUtils.uncheck(LamdbaExceptionUtils.java:95)
at cpw.mods.modlauncher.SecureJarHandler.(SecureJarHandler.java:45)
at cpw.mods.modlauncher.Launcher.lambda$new$6(Launcher.java:55)
at java.base/java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1708)
at cpw.mods.modlauncher.api.TypesafeMap.computeIfAbsent(TypesafeMap.java:52)
at cpw.mods.modlauncher.api.TypesafeMap.computeIfAbsent(TypesafeMap.java:47)
at cpw.mods.modlauncher.Environment.computePropertyIfAbsent(Environment.java:62)
at cpw.mods.modlauncher.Launcher.(Launcher.java:55)
at cpw.mods.modlauncher.Launcher.main(Launcher.java:66)
at net.minecraftforge.server.ServerMain$Runner.runLauncher(ServerMain.java:63)
at net.minecraftforge.server.ServerMain$Runner.access$100(ServerMain.java:60)
at net.minecraftforge.server.ServerMain.main(ServerMain.java:57)
